Question about Dryers
Over heated will not run but still heats
Hi I have a whirlpool electric dryer md#LER5636PQ0. It started heating when it was not on. Last load I ran I for got to turn the breaker off. The unit still heats but will not start. How do I fix this? How do I fix the the heating problem once it does start? Thanks
  • terrywhitted Apr 14, 2009
    Yes that is exactly the problem.
    thanks
  • 15,935 Answers
There are 4 things that could potentially be wrong with your dryer if its not heating up..
1. Thermal fuse - unlikely because you said it DOES heat up - just at the wrong time (when its off).
2. Thermostat - again - unlikely because it does heat up - at the wrong time.
3. Timer Motor - Most likely
4. Element - unlikely because it IS heating at the wrong time.
Since your Dryer does heat up, but stays on after the Timer should shut the element off, AND it will not start .... Your timer motor has failed.
Relatively simple to repair yourself. 15 minute job!!
Remove the back of the control panel, remove the 2 screws holding the timer on the unit and replace the timer wire for wire. The timer in place, put the 2 screws in and close up the panel. No more turning off the breaker between uses :D
So easy a CAVEMAN could do it :D
Find the New Part HERE for $62.31USD
Thanks for using FixYa - If you need further clarification about this question, please respond to me first before moving on to another expert.
THANK YOU!!
Posted on Apr 14, 2009
  • 190 Answers
Dear customer,
                     Please check the following and let me know....
  1. Check the lint trap.
  2. Check for proper air flow.
  3. Check the thermostat.
  4. Check the heating element.
please click on the blue words for details..   Thank you..
  • 1,000 Answers
Forgive me, but I want to be clear on this issue.
If the dryer button is completely off, the heater element continues to get hot and you can not get the dryer to tumble no matter what you do? If that is correct, let me know.
Regards,
It's running fine but not heating at all on any
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101--==-
Aug 04, 2011 | Whirlpool Dryers
We have a Whirlpool dryer Model number LE7680XSW2 it is electric. It runs but it does not heat. What can we do to fix this problem. We bipaseed both the thermastat and the high limit shut off and ran...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 15, 2010 | Dryers
I have a whirlpool dryer, model # LER7646EQ2 drum turns, blower works, but no heat. Pulled out heating element, no coils broken or grounding out, however part of heat sheild is blackened. Before it...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 08, 2010 | Whirlpool Dryers
Okay my dryer has been popping the CB for the last three days, I through it was the two thermostat's were replaced. Ran the dryer ops checked normal, now when I put a load of wet clothes in it runs for...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I garee with you about the motor, but it also could be the heating element heating up and shorting out...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Hotpoint NVL333EY Electric Dryer
I replaced the fuse and the coils for my Whirlpool dryer because it would heat up and then the flame would go out after it ran for 5 - 10 minutes. Now what could it be? Whirlpool Gas Dryer LGR8648LW0
heatman101
Aug 19, 2010 | Whirlpool Dryers
Dryer ran for over a hour. No heat . timer never moved
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 27, 2010 | Whirlpool LGV4634JQ Gas Dryer
My LER5636PQ0 wont heat up but it does run. Also the timer does not work or buzz when cycle is done. Help?
Check for blockages and correct that first7767bef.jpgThen unplug your dryer and remove the rear cover. This is your dryer.070f137.jpgafter you clean it up check the fuse0d461b2.jpg
May 04, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer ran all night and won't heat
Yes it will heat. The two are normally not dependent on the other. The element could be bad. Check the breaker first, then the connections in the back, then the element. The timer could be bad itself allowing it to run all night. This could be a blessing in disguise as the clothes would have been damanged possibly from all the excess heat.
Dec 26, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
