Question about Vacuums
No suction. filter and hose clear. motor high pitch. don't know how to remove cover to check motor.
No suction...hose clear....filters are clean....motor sounds like it is straining-high pitch....how do you get into the motor-romove cover. model no. 116.22812
  • 72 Answers
Something is clogged somewhere start from bottom and foolow suction path all the way through. wht kind of vacuum?
Posted on Apr 15, 2009
HIGH PITCHED SOUNDS WHEN VACCUUM IS ON
Remove all filters and turn on the vacuum cleaner and check the hose for suction.If it has good suction turn it off and remove the belt.Turn it back on and if the noise is still there you have a motor bearing squealing.It's probably time to replace the vacuum cleaner if you have a motor problem.www.sewvac.com .Most of these box store models are designed for replacement if a major component fails.
Jan 28, 2011 | Bissell Vacuums
My versatility electrolux vacuum is 2 years old and it has lost its suction, i have replaced the filters and checked every hosing area i have access to, it seems to all be clear. I dont know what else to...
It sounds like the fan blades have worn away until there's basically no air resistance, thus no air flow/suction. The whine is created by the motor turning at a higher speed due to lack of resistance.
The fan wasn't covered by the warranty, anyway.
It's time to either replace the motor/fan assembly or buy another vacuum.
Sep 20, 2010 | Electrolux Vacuums
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like...
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Sep 10, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My hose no longer works no suction buth the vacuume still works how do i fix I checked the hose checked the filters nothing works to get my hose so it has suction.
Check the following after unplugging the power cord from the outlet.
- Check for suction at the back of the unit, after removing the hose where it attaches to the back of the vacuum. If there is NO suction, the machine will need to be taken to a local Service Center for inspection.
If there IS suction at the back of the machine with the hose removed, please check the following:
Unplug the unit from the outlet.
- Check the Pre and Post-Motor filters for debris. Dirty filters can restrict airflow. The pre-motor foam filter is square and located in a pull out tray underneath the dirt cup. The foam filter may be hand washed in cold water with mild detergent. Reinstall the filter when it is completely dry. The post-motor HEPA Media filter is rectangular and located on the side of the machine. Note: The white HEPA Media Post-Motor Filter is not washable.
- Ensure the dirt cup is empty.
- Check the upper tank for build up or clogs.
- Twist the inner cyclone to the left and pull down
- Wipe the inside of the upper tank and separator plate with a
damp cloth moistened with water or mild cleaning detergent.
- Once the inner cyclone is dry, lock back into the machine by
pushing up and turning to the right.
- Put the dirt cup back in
- Check for good suction at the end of the upholstery hose. If there is good suction, make sure the hose is firmly connected to the lower hose on the back of the vacuum. If there is no suction at the end of the hose, check the hose for splits, cracks or clogs.
- Make sure the brush is rotating. If it is not, remove the access plate and examine the brush, and belt for damage. The access panel can be removed by lifting the 4 tabs located at the bottom of your machine. Lift tab 1 then 2-4 tabs to remove the access panel.
CLEARING CLOGS
- Detach the upper hose from the machine. Insert a broomstick into the hose to push any obstruction through to the opposite end.
- Remove the screw from the left side of the lower hose on the back of the unit, and straighten this section of hose by pulling it down or lay the unit out flat, and roll the unit on its side with the lower house towards the top side. Look through the hose for any obstructions. Push a broom stick through the lower hose to unclog.
Aug 12, 2010 | Bissell Upright Vacuum - The Pet Hair...
My dyson vacuum motor is sounding very high pitched... The tubes are all clear and there is suction with the tubes not not real good suction on the beater brush area....
Your dirt path is clogged, probably not far from the brush area. This is the reason you noticed the hi-pitch sound coming from the motor.
You may have to remove the hose to clear it.
Jan 19, 2010 | Vacuums
My vacuum is making a high pitched sound and has no suction from the hose?
hi, what this points towards is a blockage either in the pipe or where the filters are, if you dont unblock it then it will over heat and blow the motor.
This is a very common fault for this make of vac and they dont tend to last long anyway.
Your best option would be to remove the part you empty and take out any filters you can get access to give the filters a good clean by banging them on a wall to remove any build up of dust and hair.
The have a look at the pipe try and take the pipe off the usual place for blockage is where the pipe goes into the vac so check here for blockage its usually just a build up of stuff you have vac up that has caused a blockage.
as you have no suction from the hose you would then have no suction at the floor part so dont try using it like it is . you need to remove the hose its either screwed in or held in by two plastic clips that you can push with a screwdriver once you have undone this you should be able to see the blockage.
Let me know how you get on or if you need further assistance ok
Jan 18, 2010 | Kenmore 31913 Progressive Direct Drive...
Losing suction filter clean,hoses clear,output blower good,but very poor suction
if the blower is much stronger than the suction, you may have an air leakwhere the cover fits on tank or possibly a warped tank or cover. feel all around the unit for air being drawn in somewhere besides the hose. try it without the hose on and block the inlet for a couple seconds to see if the unit leaks air in. also replace the filter , dont try to clean it, the pores clog and reduce suction and damage motor.
Jun 11, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Bissell lift off vacuum about 4yrs old. Extremely noisy. OK until before Christmas but getting worse every time it's used. Washable filters washed, HEPA filter replaced. brush bar cleaned of every scrap,...
Sounds like a bad motor bearing. If it is, then you would have to replace it. Could be the brush roll, did you check the ends to make sure they turn easily?
Apr 30, 2008 | Vacuums
Vacuums Logo
287 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
