Question about Brother XL-3510 Mechanical Sewing Machine
Thread looping on top and bottom of fabric
I am trying to sew a baby blanket with 2 layers of flannel. The thread is looping on top and bottom of the fabric. I have tried making the tension tighter and looser, changing the needle for a different size, re-threading the machine, re-loading the bobbin and it still looks like junk. Please help.
  • xray_butterf Apr 14, 2009
    If I set the stitch dial to 12 then I don't end up with a straight stitch, some decorative stitch.
  • Anonymous Mar 12, 2014
    thread tension set at maximum and still forming loops on bottom of fabric
  • 374 Answers
Hi! there,
on this condition,you can avoid wasting time and material try on this, the problem is your set up of tension thats why.,but you should follow upper theading. see figure,Thread looping on top and bottom of fabric - c978815.jpgthis just sample of exact threading,next bobbins set up see fig.the thread should be clockwise rotation on winder5a00a72.jpgfollow this set up,and upon inserting be sure
you have clean feed dogs and shuttle race free from fabrics and threads chips.set dial tension to #3 to #4 and stitch dial to #12.then try this set.and you can watch on you tube sewing. try this stuff on internet address type www.youtube.com then on search box type sewing machine,have enjoy and have a nice day.don't forget to rate me,
Posted on Apr 14, 2009
Baby lock quest plus and the bobbin thread is all loopy. I have done everything. I believe it is in tension discs. When I move it to 8 or 9 it sews ok. When I sew faster it seems to start looping.
Is it really the bobbin thread that is loopy--not the top thread looping under the fabric? If this is the case, it is called bird nesting. (problems appearing under the fabric are usually a top thread issue, problems on top of the fabric usually indicate a bobbin issue)
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. You may need to loosen the top tension to get it where it should be. The two threads should meet in the middle of the fabric.
If the bobbin thread is still too loose, then an adjustment may be needed to its tension.
Understanding Thread Tension Threads
Feb 10, 2018 | Baby Lock Sewing Machines
Bottom thread is looping on top of fabric on my Singer Futura 400 machine
Thread looping can also be caused by the use of adhesive stabilizers. During embroidery, your needle can gum up. Try floating a sheet of wax paper on the bottom to see if that might be the cause (along with the above solutions, of course).
Mar 04, 2014 | Singer CE250 Computerized Sewing Machine
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
Bobbin thread bunches up
make sure the bobbin is inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint & loose threads
make sure the bobbin is wound correctly
make sure the thread has not come off the thread take up lever
Mar 28, 2012 | Singer Sewing Machines
I have a singer 7258 that I can not get the tension to loosen up on. The top stitch is straight across and adjusting dial doesn't help.
Hello
Adjust the tension
Load your sewing machine with one color on top, threaded through the needle. Load the second color thread into the bobbin and thread.
Fold the scrap fabric in half, and sew a straight stitch at least 2 inches long. Look closely at the seam. If you see loops of the bottom color thread on top of the fabric, proceed to Step 3. If you see loops of the top color thread on the bottom of the fabric, proceed to step 4.
Loosen the top tension. Since the top tension is so tight, it is pulling the bottom thread up through the fabric. Loosen the top tension by turning the numbered knob on the front of the sewing machine counterclockwise by one number.
Tighten the top tension. Since the top tension is too loose, the bottom thread is pulling the top thread down through the fabric. Tighten the top tension by turning the numbered knob on the front of the sewing machine clockwise by one number.
Sew a straight stitch 3 inches in length. Check the stitching. It is perfect if the threads meet in the middle, and you can only see the top thread on top and the bottom thread on bottom. If it still needs adjusting, go back to step 2 to repeat the needed steps.
Using two different colored threads makes it easier for you to see which thread is being pulled.
Always use proper precautions when working with electrical machines.
Aug 01, 2011 | Singer Sewing Machines
I am sewing through 4 layers of fabric and the needle isn't going through and catching the bobbin thread. What should I adjust? It was working fine through 2 layers of fabric.
The reason it is not sewing is because when the needle goes through the 4 layers of fabric the thread from the needle is not abloe to form a loop for the hook to catch, try turn the tension down a bit.
Apr 21, 2010 | Sewing Machines
Pulls bottom colored thread to top...how do I ajust New Home 8000 trying to zig zag and bottom thread pulls color to top....
The bottom thread is the bobbin thread and it is suppose the pull the top thread slightly to the bottom/center of the layers of fabric.
Try a lower tension setting and a tear-away stabilizer or sheet of printer paper under the fabric to see if this will help hold the top thread down into the fabric.
Mar 27, 2010 | Sewing Machines
Singer 301a...sews on top of fabric nicely...bottom is just loose loops of thread...it's like the bobbin is not sewing...I put 2 different colors in to see...top is perfect...on bottom of fabric I see the...
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Jan 25, 2010 | Singer Sewing Machines
Brother XL-3510 Mechanical Sewing Machine Logo
483 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
