Question about Kenmore 24 in. 16029 Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
Diswasher malfunction - won't start clean light flashes 7 times The clean light keeps flashing green. Can't get the washer to start. The only operation it will do, is drain when the cancel / Drain button is pushed This unit is: Stock # 16029 Type # 575-0 Model # 665.16029.402
  • 3 more comments
  • ncwilson Apr 24, 2009
    Green light flashing - can drain with Cancel/Drain button but that's it
    Kenmore type 575-0 model 665.16029701
  • Anonymous Apr 26, 2009
    Seven flashes of the clean light.  Manual says "heating element problem."  My product:  665.17039401
  • Anonymous May 08, 2009
    diswasher malfunction - Mine won't start and green clean light keeps flashing. The only operation it will do, is drain when the cancel / Drain button
    is pushed This unit is: Stock # 16029 Type # 575-D Model #
    665.16029.402
  • Anonymous Mar 14, 2014
    flashing 7 time
  • Anonymous Mar 17, 2014
    clean light flashing 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Posted on Apr 14, 2009
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: diswasher malfunction - won't start clean light
This information may help in your situation. This can be a common problem on some Whirlpool manufactured dishwashers. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Nov 10, 2009
Kenmore dishwasher won't restart, green light flashes 7 times
Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Apr 29, 2014 | Dishwashers
Flashing orange fault flashes four times whirlpool
4 flashes on whirlpool diswasher usual means a draining problem clean out your filters
Feb 02, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Diswasher malfunction - won't start clean light flashes 7 times The clean light keeps flashing green. Can't get the washer to start. The only operation it will do, is drain when the cancel / Drain button...
Nov 10, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher malfunction
BAD WATER SELONOIDE, OR BAD BOARD
Dec 18, 2007 | Dishwashers
Kenmore 24 in. 16029 Built-in Dishwasher Logo
1,958 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
