Question about NAD Audio Players & Recorders
NAD 705 Receiver won't power up
When I plug the unit it and push the power button-there is no power. Is there an internal fuse for the power supply that needs replacing and where inside would I find it? :(
3 Suggested Answers
SOURCE: NAD 705 out if order
As the display lights are blown, you can't see that the unit is in the wrong 'listening' mode. USe the Listen switches to get to the input you are tring to use. The blown lights can be replaced with White or Blue 'wide beam' LED's, one leg connected in series to a 6k-ohm resistor.
Posted on Feb 13, 2008
SOURCE: NAD AV713 receiver won't power up
I had the same problem with mine AV713 it turns out to be the relais of the power unit (left site above the transformer). solution may be to replace it with http://ecb.omron.com.sg/pdf/relay/power/G5PA-1.pdf e.g. good luck TB
Posted on Jun 18, 2011
My NAD C372 integrated amp was working normally everyday. One day, on pushing in the "Power On" button, it did not light up. No response at all.
It could be anything from a blown fuse from a power surge to a shorted capacitor ijn the power supply. There are fuses in all amplifiers. Locate it and test it with an ohmmeter.
Dec 16, 2013 | NAD C372 Amplifier
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
Its not getting any power and the fuse is not blown
Hello there,
Check the plug that the receiver is plugged into with something that you know for 100% sure works if the wall jack has power , move onto the next step
Check all the connections at the Receiver, both ends of the power cord if this no power
plug the receiver in and see if you can hear it start up or make any sounds at all, also try pushing the button on the front of the receiver if you still get nothing its a bad power supply on the unit and it needs to be repaired.
I hope this was helpful don't forget to Rate
Jan 26, 2011 | Audio Players & Recorders
The power does not come on when the "On" button is pushed. What's the problem?
Hi:
Check near the power input connector for a small fuse compartment, the line protect fuse may be blown and in need of replaceing. If there is none then the power supply is not getting power the fuse may be internal to the unit. Or the pwr supply has failed entirely, but check the simple solutions first, usually no power is due to the printer being plugged in an switched outlet or blown fuse or power supply failure.
Aug 24, 2010 | HP LaserJet 5si mopier Printer
We bought a new garmin 705 and the speed records but not the distance or other features
The Garmin Edge requires that you press the start/stop button to record any data.
1. Before you start riding, press the start/stop button to begin recording.
2. Once you have finished riding, press start/stop button to end recording.
3. Create an account on connect.garmin.com and plug your unit in using the supplied USB cable and download your ride to view details on your cycling session.
Aug 14, 2009 | Garmin Edge 705 Handheld GPS Receiver
No power at all on NAD C370
User manual here
http://nadelectronics.com/img/manual/NAD-C370.pdf
Read page nine for some simple troubleshooting tips and see if that helps.
It *could* be a fuse but given you've owned it for a while and NAD amps often have capacitor issues in the power supply, chances are it needs some serious work by a good tech. Contact NAD directly and see what they recommend.
Dec 29, 2008 | NAD C370 2-Channel Amplifier
Stand-by light on, but receiver won't power up
Power supply problem. Most equipment today has remotes and the power supply has to remain on to sense the remotes signal.
But the actual receiver section does not get power until the remote says so or you hit the power on button on the unit. Internally the supply then feeds the device. Most likely cause is a power surge or storm.
See if the remote will power it up?
I presume this is still under warranty. If you don't have it plugged into a good surge supression outlet strip, Get one!
Mister Phil
Apr 05, 2008 | Audio Players & Recorders
Nov 20, 2007 | Sony A/V Receiver
This seems to be continuin problem with those. Not sure of exact fix yet, but believe it is just a fuse or bulb that needs replaced.
Sep 01, 2007 | Audio Players & Recorders
186 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
