Question about Sony PlayStation Portable (PSP) Console
I keep getting disc can't be read.
I have reset my PSP to factory default settings but I still keep getting the same thing.
Its the laser thats messed up or if thats not it i dont know anything else other than to get a new one.sorry
Posted on Apr 17, 2009
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
How to restore default settings
Hello :
  1. Remove the battery from the left side of the PSP while it is still on. The unit will power down instantly. Wait ten seconds and then replace the battery.
  2. Press both clear shoulder buttons at the top of the PSP and keep them held while the PSP reboots. A "Recovery" mode will be initiated.
  3. Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
Warnings
  • If you would like to reset your PSP while it is working normally, you can do so by going to the Settings menu and selecting "System Reset." This will get rid of all your content and restore the PSP to factory settings (and subsequently remove all of your content.)
Or try this for hard resetting :
  1. Locate your Power button on your PSP. Push the power button up for 10 seconds.
  2. The PSP will and should shut off. Leave the PSP off for 30 seconds.
  3. Turn your PSP back on by flicking the power button up very quickly. If it doesn't turn on, try pushing the power button forward very quickly again. (sometimes you have to do it 2-3 times)
  4. Your PSP should be working now. If not, then you may have a firmware problem.
Warning:
  • Do not have your PSP plugged into a power supply.
  • If your PSP doesn't turn off after 10 seconds (of power button being help up) then remove your battery and wait 30 seconds, and then replace .
PLEASE RATE !
Jun 08, 2010 | Sony PlayStation Portable (PSP) Console
Will resetting the factory default settings allow me to change the password w/o knowing the password? Why would you need to reset factory default settings anyways? Also, where can I get a PSP 2000 manual?
the manual can be found here. for all sony game systems.
http://us.playstation.com/support/manuals/index.htm
you would need to reset to factory default setting for the exact problem you are having -- forgetting the password. so your question is "YES".
The Restore Default Settings feature will erase any previously saved settings and restore all of the settings to the default.
  1. From the XMB™ home menu, go to icn_settings.gif (Settings) > icn_systmsetting.gif (System Settings) > [Restore Default Settings].
  2. The message "Do you want to restore the default settings?" should appear. Select "Yes" and press the icn_btnx_color.gif button.
  3. You will then see a message, "All settings will be returned to default settings. Are you sure you want to continue?" Select "Yes" and press the icn_btnx_color.gif button.
  4. All settings are now restored and the system password is reset to "0000".
  5. Press the icn_btnx_color.gif button to restart the system.
  6. Re-enter system settings as appropriate.
this is the site i got the info from
http://us.playstation.com/support/answer/index.htm?a_id=538
May 20, 2010 | Sony PlayStation Portable (PSP) Console
I want to reset it
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
How to keep internet in my psp?
Hi sumu_astronu,
Based on your concern, I suggest trying the following steps:
1. Turn your PSP on.
2. Make sure that your WLAN switch is turned on.
3. Perform a factory reset.
--> To do this, select "Settings", then select "Restore Default Settings". You will not lose any information or data by performing this step.
However, you may need to reset your wallpapers. Set your name, date, time, etc...
4. Power down your PSP then wait 10 seconds, then power it on.
5. Navigate to "Network Settings".
a. Select "Infrastructure Mode"
b. Select "New Connection" Name this connection as you deem appropriate.
c. Navigate to "WLAN Settings" Select "Scan".
d. Your router should now be listed.
e. Navigate to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None"
f. If you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA..
g. Navigate to "Address Settings". Select "Easy"
h. Navigate to "Setting List". Verify that your settings are correct.
i. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
j. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
Hope it helps,
Thank you for using Fixya.
Mar 15, 2010 | Sony PSP (Piano Black)
I got Error 80110404 from my PSP when I setting connect the internet and network too.
Reset your PSP to factory defaults.
If this doesn't work then that means there is a problem with the built in wirless card in the PSP and you would need to send in your PSP to Sony to be serviced or get another PSP.
Nov 29, 2009 | Sony PlayStation Portable (PSP) Console
Connecting to the internet. keeps saying check my network settings
id be happy to help
Instructions
1 Take out the UMD disc from the back of the PSP if one is inserted. 2 Take out your memory card from the memory card reader if one is inserted. 3 Turn on your PSP. 4 Go to the "Settings" tab in the Cross Media Bar and select "System Settings." 5 Select "Restore Default Settings" and confirm that you wish to restore all settings to the factory defaults. 6 Restart your PSP. 7 Try connecting to the Internet again. If you still get the 80410A0b error, try connecting to another network. If you successfully establish a connection to another network, your router is at fault. If you cannot connect to the second network, your PSP's Wi-Fi card could be damaged and may need repairs. Tips & Warnings
Ensure that you are entering the Wi-Fi SSID and password correctly on the PSP. You can contact PlayStation Support (see Resources) to start a repair order if you PSP's Wi-Fi card is faulty. if you require further assistance please let me know and i will be glad to assist you. Thanks
Nov 01, 2009 | Sony PlayStation Portable (PSP) Console
Trying to connect to internet on my sons psp but cant remember the password that was entered,and i cant set up the internet on his psp , testing connection is failing
Go to your Settings, System Settings, and click on Restore default settings. Doing this resets everything to factory settings. Don't worry, it ONLY resets settings. It won't delete anything on your Memory Stick. This feature resets your nicknames, any passwords, and along with Flash player and WMA playback. This will work. When you are done, it will be as if you just got your PSP. Your data will still be intact. However, if you're talking about not knowing the password on your Wi-fi network, then you'll have to contact the provider.
Oct 22, 2009 | Sony PlayStation Portable (PSP) Console
I dont kno the 4-digit password
You need to reset to factory settings:
  1. Go to Settings
  2. Go to System Settings
  3. Go down to Restore Default Settings
  4. Hit Yes
You should be good to go now with a 4 digit password of 0000
Feb 01, 2009 | Sony PlayStation Portable (PSP) Slim...
Sony PlayStation Portable (PSP) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
