Paper jam error message won't go away
Good morning - my canon pixma mx318 had a paper jam. i took out the jammed paper and nothing is left inside, but the printer still displays the error 'paper jam, clear the paper and then press 'ok''. i shut down the printer several times, i rolled two sheets of paper through and still i get the same error message. can anyone help me, please? susanna
Inky
  • 691 Answers
SOURCE: Pixma i4000 - manual feed picks up 2 to 3 sheets at a time
Get a window cleaning product such as windowlene and a soft but LINT FREE cloth. Remove any paper from the feeder and turn off the machine
Look into to sheet feeder and identify any rubber areas. There should be a rubber pick up wheel and just beyond it a separator pad. There may also be a cork pad in the vicinity.
Use your cloth well dampened and clean all these item as best you can. You can rotate the wheels but ensure you go the correct direction and do not force anything that does not want to move. This will be chore as access is only easy for pixies. Once you have then cleaned and dried off, replace the paper and restore the power.
Try running a print job and see if it makes much difference. If it helps, then you will know that the pick up wheel and separator pad are worn out and could do with replacing.
The paper jam error is related to this issue as the printer is expecting the leading edge of the paper to pass its sensor and then 297mm later the trailing edge should pass the same point. If the machine feeds more than one sheet, the chances are that the paper length will be altered and the machine thinks a bit has been left behind.
Let me know how you get on
Posted on Oct 16, 2007
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Driver for Canon PIXMA MX318
you can go to radar sync.com and download their free driver utility it has worked well for me best of all it was free
Posted on Mar 21, 2009
Canon pixma mx432 how to reset paper jam error msg.
Canon Printers Have a door at the back to remove the jammed paper, If the tiniest piece is left in there you will still get the "paper Jam" Message. Make sure you have looked closely and well inside for no paper left :-)
Jun 10, 2014 | Canon PIXMA MX320 Color USB InkJet Printer
No paper jam but error 5110 won't go away
Have you tried unplugging the machine, this might reset it.
Mar 14, 2013 | Canon Pixma MP500 All-In-One InkJet...
Hello, I got an error message 5C10. What does that
I just had this error message appear on my computer screen and the 6A00 on my MP830 printer at the same time. I heard this error mean a few things (paper jam, ink carriage stuck), though not sure what it does actually mean. I moved the carriage back-and-forth, blasted compressed air and checked for paper jams. When nothing worked, I looked inside and saw a lot of spilled ink, I'm guessing from not using genuine Canon ink. I blotted the inside with paper towels (use gloves!!),especially the far right, and took out the ink cartridges and blotted the carriage. I replaced everything, powered the printer off and on, and it worked fine. I would suggest first to slide the carriage back-and-forth and look for paper jams before cleaning the ink. Hope this works for you.
May 25, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Pixma mx318 paper jam
The first thing I would do is check if there is any small fragments of paper in the printer. If you still cannot see anything, try getting some compressed air and blown the printer out. If that still dose not fix it, you might have a faulty paper sensor. If the printer is in warrenty, I would try and do a warrenty claim.
Aug 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Won't print, and shows Error Code 3
Check to see if anything is stuck inside. Sometimes a small fragment of paper gets stuck inside and triggers the "jam" message.
Feb 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
257 people viewed this question
k24674
