Question about Microsoft Office Standard for PC
EXCEL FORMULA I HAVE PEOPLE AS NUMBERS LISTED IN COLUMN "E" AND I HAVE THEIR NAMES ELSEWHERE ON THE PAGE. I NEED A RUNNING TOTAL BY EACH NAME HOW MANY TIMES THEIR NUMBERS SHOW UP IN COLUMN "E". I TRIED AN IF STATEMENT BUT IT DIDN'T WORK. AND I HAVE BEEN GUESSING EVER SINCE. PLEASE HELP. THANKS
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Try using the formula "sumif". It allows you to sum by category/name. Good luck! D.
Posted on Sep 12, 2007
Sum numbers in a column down until you come to a blank, then start again
Sounds like your issue can be solved readily with a pivot table.
If you give the columns of names a title like "NAME" and the number columns a name like "VALUE". All other columns should contain a unique name.
Then select the entire table, including the labels at the top ensuring that the range extends entirely over the column you need to sum the values of.
In Excel 2013, choose the INSERT menu and select the PIVOT TABLE command.
Insert the Pivot table into a new worksheet.
A new sheet will open with a strange-looking control panel on the right of the window.
Make sure that the box for NAME and VALUE (only) are checked
You will notice that Excel assumes that you want the SUM of the values for each NAME summed. The results are in the leftmost area of the worksheet.
If this works for you, please vote my answer as "helpful".
Sep 03, 2014 | Microsoft Excel for PC
Excel Spreadsheet question
cells are referenced by column and row. columns use a letter reference and rows use a number reference. to reference pages use the page name. For example if you are entering a formula in a cell on a page named sheet2 and part of the information is located on the page named sheet1, you would use a reference as follows:
sheet1!C3 This reference is for the cell on the page named sheet1 in the third column and the third row.
Hope this helps
Apr 09, 2014 | Microsoft Excel for PC
Excel cell replacement
To have the contents of the cell change from something you input into something else, you would need to put in a macro using VBA. You'll need someone who knows VBA to help with that.
OR... It is a lot easier to get similar results, if you are ok with using a few more cells to do it. The item# will remain where it was entered, and the product name will have to go in a different cell. In that case, you can use a lookup formula.
To do this, lets say your item# is entered in cell 'Sheet1'!C1, and you want the product_name to display in cell 'Sheet1'!D1. On another sheet (lets say sheet2) In cells 'Sheet2'!A1:B5 input the item#'s in the first column (column A1:A5) and input the matching product-names in column B1:B5. This is your lookup data. This sheet can be hidden if you want In cell 'Sheet1'!D1, use a vlookup formula that will look at the item# and find a match in the list, and display the product name for you. =vlookup('Sheet1'!C1,'Sheet2'!$A$1:$B$5,2,false)
This will display N/A# if the number can't be found.
Feb 15, 2013 | Microsoft Excel for PC
Create a program that will the salary, no of hours work, the deduction, total deduction and net pay.
The easiest way to do this is to use Excel spreadsheet.
This is what you need to do.
Create a label at the top of each column as detailed.
Add a employee to each row under Name of employee
Then against each employee add the data and the formula in the relevant cell under each column.
The first column - Name of the employee
2nd column - salary rate per hour
3rd column - hours worked
4th column - gross pay (formula = salary rate X hours worked)
5th column - tax deduction
6th column - other deductions
7th column - total deductions (formula = tax deduction + other deduction)
8th column - net pay (formula = gross pay - tax - total deductions)
At the last row you can include a total for Gross salary paid, total Tax collected etc.
Once you have setup this spread sheet make a copy of it and save it as a template.
You can then copy this template for each new financial year so you do not have to create a new one each year, you only need to make minor changes for new employees, rates of pay etc.
Another way to make a salary program is to use Access Database. You need more skills to do this, but it can provide greater reporting capabilities.
Mar 24, 2011 | Computers & Internet
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
Hi, I'm workin in Excel 2003 and I have column A that it has names (they could be repetitif names). Column B that it has dates (it could be repetitif dates but not for the same names in column A) and in...
I'm certain that I can solve your problem...
Can you send me a xls file with you data to my e-mail (pfjota@gmail.com) so that I can try with real data ?
Send these explanation with your email to !
Thanks
May 01, 2009 | Computers & Internet
Excel lookup - match index array
The best solution may be to re-define the named columns, or to add new names to multi-column arrays, then use the VLOOKUP function.
Note that the "indexed" named cells must be sorted by the index column.
Test (this is a 2 year old question)... Please ignore ths following. The plus symbol does not display.
Upper key plus symbol displays:
Right plus symbol on number pad displays:
[Shift] Right plus symbol on number pad displays:
[Alt] [4] [3] displays:
slash/slash/plus displays: //
slash/plus/slash displays: / /
Plus Plus Plus displays:
upper Plus Plus Plus displays:
Shift Right plus plus plus displays:
end of plus test.. thanks.
Dec 09, 2008 | Microsoft Excel for PC
Related MS Excess 2003
Hi Esd,
I'm assuming you meant 'Excel' since 'SUM' is the command you're looking for.
If your totaling Column D for rows 5 through 35, this is what you would need in the cell your total would be:
=SUM(D5:D35)
Also, when in doubt, Click on the '=' (equal sign) in the formula bar for a list of functions and help using them.
Any problems? Click the Askme button near my name.
Thanks for using Fixya.
Mike
Dec 06, 2008 | Microsoft Computers & Internet
Using NOW() in excel formula
That sounds like Excel. You may have to get someone locally to fix that problem.
Jun 10, 2008 | Microsoft Windows XP Professional
Microsoft Office Standard for PC Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
