Question about Kenmore Dishwashers
K-more elite dishwasher stuck in sensing mode; won't move to wash
The clean light was stuck flashing on my kenmore elite dishwasher. I used the sequence off your website to correct that problem. I've now started a new cyle but it's stuck in sensing mode and won't move into the wash mode. Any ideas??
Where did you find the sequence to clear the flashing clean light?
Posted on Apr 14, 2009
Clean cycle light is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 22, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
It doesn't start and clean light flashes Kenmore Elite dishwasher water supply is turned on overfill protection float is able to move up and down freely there are no sudes in dishwasher soap dispenser...
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Jun 07, 2010 | Dishwashers
What is the sequence to reset our kenmore 16052
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 24 in. 16052 Built-in Dishwasher
I have a kenmore elite dishwasher 577-9 17262402. The clean light is flashing. How do I stop it from flashing to start the dishwasher?
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 21, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
Kenmore elite keeps flashing red on smart wash button. It won't do anything else.
Feb 18, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite dishwasher Options light up but nothing runs.
Jan 26, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Jan 09, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Sensing light comes on and then the timer stop going down
I do nto have a solution- just the exact same problem. My machine gets stuck on 76 when doing a "normal wash" . last night I hit cancel and drain, then went to "time saver" and ran the wash and it seemed to work fine. Funny that both of our amchines stop at 76. Any ideas?
Nov 18, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
1,020 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
