Question about Whirlpool Refrigerators
COMPRESSOR BUZZES FOR ABOUT 5 SECONDS AND STOPS. FRIDGE IS NOT COLLING AT ALL.
  • tnhrdluck Apr 14, 2009
    THANK YOU FOR SUCH A QUICK RESPONSE. THOUGHT THIS MIGHT BE IT, SO NOW I AM SURE.
  • Anonymous Mar 19, 2014
    compressor working and also the condensor fan is working but it want freeze or cool. when compressor comes on you hear a buzzing noise
    Guru:
  • 462 Answers
Either your compressor is broken inside or the start components are not working properly.  Ohm the compressor terminals to ground and across to each other. If any read anythign to ground the comnpressor is bad. Your readings between the compressor terminals shoild all be differant and you should have 1 low 1 medium and 1 high resistance readi9ng. add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals. Assuming the above checks out: Get a new relay and overload (and capicator if it has one) In other words everything that is external  and attached to the wires or terminals on the compressor,and replace them on the compressor. Then if it starts problem solved if it still does same thing the comprtessor is bad (broken mechanically inside the comprressor) and you have to decide to replace compressor or replace the refrig.
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify asnythign you dont understand.
Posted on Apr 14, 2009
UNIT (ABOUT 4 YRS OLD) STOPPED COOLING FREEZER AND FRIDGE AND MAKES A BUZZING NOISE ABOUT EVERY 5 MINUTES.
buzzing noise is possibly the compressor tring to restart. It sounds as if the compressor is going into thermal overload. I would suggest the replacement of the compressor. Good Luck
Dave
Jul 24, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
My maytag refrigerator started making a buzzing noise every time it goes on. it lasts about 5 seconds then clicks off. any idea what it is?
I have the same problem. It is ice buildup around the evaporator fan that begins as a buzzing (the fan blades hitting the advancing "glacier"), which ultimately stops the fan and then the freezer/fridge stop cooling. Just pull the lower sheet metal from the inside rear of the freezer (need to remove some screws from upper sheet also) and chip the ice away. I've got a question in to Maytag now to see how to prevent this from recurring. I've had to take the thing apart 3 times in 2 years.
Jul 21, 2009 | Maytag MSD2651 HE Side by Side...
Clicking, buzzing, compressor too hot, thawed out
Sounds like the compressor is in thermal overload. Let it cool down completely and meter the starting amperage on start to run. The compressor could be seized or it's windings could be shorted to ground (checking the resistance between the windings terminals on the compressor while unplugged will determine this.).
Jul 14, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Roper Side-by-Side Refrigerator Problem
Try changing the relay (in black box) on compressor.
Apr 26, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Buzzing sound, freezer nor fridge cooling
sounds like a compressor issue, perhaps the good news would be if its just under 5 yrs, youll have a 5 yr warr onthe compressor assy.( you should anyway) ck your manual for warr info
Nov 20, 2008 | Frigidaire FRT21H8 Top Freezer...
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Kelly
Jun 18, 2008 | Refrigerators
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
REF AND FREEZER STOP COOLING
We had a repairman come out, said it was the compressor, bad news...$650 if he repaired...good news...compressor under manufacturer's warranty for five years so you may want to call Maytag. It will be less expensive if the part is covered and you only have to pay for labor. Hope this helps. Bought our fridge 12/2004 so it was covered.
Feb 03, 2008 | Maytag MFD2560HES Bottom Freezer French...
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
119 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
