Question about PNY Attach? 16GB USB 2.0 Flash Drive
Pny 16gb attachi flash drive reccognized by my computer but says insert disk into drive when I left click it
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Jan 31, 2010
My computer thinks my pny 32GB USB 2.0 flash drive is a disk
All pen and SD cards show up as removable hard drives. Removable or not they can be treated the same. You can format again just by right clicking on it, or use diskmgmt.msc to fully manage via the MS management console.
It's basically doing the same as you did from the cmd prompt.
If you asking to restore files, then you require a 3rd party software. There is Recuva (free), Wondershare, and Stellar. They all do the same thing.
Dec 11, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
Is the pny 16gb flash drive fat32 formatted?
click start click on my computer you should see your memory card
right click then select format
another way is to control panel administrive tools computer management disk management right click on your memory card or it might be listed as a mass storage device
select format
you will see what its formatted in
hope this helps
Jul 14, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
Format a 16gb PNY Micro SD
Format it by using a device like a camera, the computer will not work to format this type of memory. I know this from own experience with 4 different computer in my house..
Jan 16, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
My I Mac won,t reconize my PNY 4 gb usb Flash drive when I insert it
Try reformatting it:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Aug 17, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY is not working
the computer is not seeing it properly un plug,then refit ,are the contacts clean,
Jul 06, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Need driver for pny 4Gb Pendrive. It is saying Please insert disk when i try to open my pendrive. it is displaying in Devise manager.
Normally most of the pen drive are plug and play means the hardware is recognised automatically by windows.
Try the following steps below:
>start
>setting
>control panel
>administrative tools
>computer management
>in left column click disk management
>then you can perform format according to your choice.
ok try this and let me know
Any other help, you are most welcome
Regards
Uttam
Jan 26, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
I have a pny 4 gb mini attachi usb 2.0 drive. i need to store my photos and files off a laptop. how do i begin and what do i do.?
Connect your Pny attachi to USB port on your laptop using USB cabel available with your attachi, your laptop will detect the external device automatically and or it might also ask you to install drivers which you can install using CD available with Pny, once you have done you can easily transfer and share anything you want.
Sep 05, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY Attach? 16GB USB 2.0 Flash Drive Logo
1,539 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
