Question about BenQ PDP-46W1 46 in. HD-Ready Plasma Television
Remote does'nt work
I have a BanQ 46w1 46in plasma, the remote does'nt work like there is no signal from the remote to the tv, i replace the battries with new ones and it still not working, anyone knows how i can fix it.
Hi: Hope you got your set fixed but if not whould like to buy it to use it for parts to try to fix mine firured if I get 4 or 5 sets I can make mine work maybe?
Posted on Nov 27, 2007
SOURCE:
My freesat remote just stopped working. Ive put new battries in, turned box off and on, disconnected and reconnected it but the remote just wont work anymore please help me
Have you got a video camera? Here is the trick to find out if the remote doesn't really work, or it's the TV that is not picking up the remote signal. Most remote use an infrared led to beam signals to the TV's. And this trick will show you whether that remote's LED is actually working. You and a friend or member of the family is all you need to begin testing your remote. Ask your friend or family member to hold the remote and you hold the camera on without recording. Point the remote about 5-6 feet from the camera. You watch the camera monitor screen while your friend or family member presses the On button or presses the buttons that you think are not operating the TV. With a dim room light, you should be able to see a flickering light coming from the remote in the camera screen. If it's hard to see, which I doubt, since remote infrared LED are pretty bright, you can turn your room lights off and try again. If the flickering LED from the remote is seen and is bright, then try all the buttons on the remote, or at least try the ones that you say are not working with the TV. If all is well, then there is nothing whatsoever wrong with the remote, but chances are that though the remote may beam out infrared light, it doesn't mean it is the right frequency for the TV. It could have lost the frequency and no longer sends the correct signals for the TV. However, the problem can also be with the TV remote's LED receiver. This falls into the hands of a technician's inspection on whether the receiving end of the remote is effective or needs replacement. In this part, you need to have the TV checked.
Nov 17, 2014 | Televison & Video
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Fujitsu Siemens plasma TV P50 - works ok - the problem is the remote control, always been a problem - bad signal ? it was nessesary to directed very exact towards the TV and not too far away/less than 3 m/...
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://schematicscom.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
May 13, 2017 | Fujitsu Siemens MYRICA P50-2 50 in. Plasma...
My Tv Remote GXDB DOESNT WORK ANYMORE HOW DO I GET A NEW ONE I PUT IN NEW BATTERYS AND STILL DOESNT WORK tv is only a year old
Please look here:
http://www.google.com/search?q=sanyo+gxdb+remote&hl=en&rlz=1T4GGIH_enUS282US283&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yClfTdL3EI2osQPE8dDPCA&ved=0CC0QrQQ
Or Google 'SANYO GXDB remote"
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
Please leave rating if it helps.
Feb 19, 2011 | Sanyo DP50747 50 in. Plasma TV
My remote worked intil I changed my battries in the remote and know it doesnt work. Cant program it to turn on the tv
Make sure you put the batteries in correctly (reversed polarity) and that the batteries are good.
Jan 31, 2011 | Sanyo DP50747 50 in. Plasma TV
Remotes stopped working
Have you tried contacting LG. They may be able to help you out
Jul 19, 2009 | LG 32LC7D Television
My 42 inch Haier Plasma has a no signal on screen it's only a year old can someone help I bought a new remote and that did not help ?
i had the same problem and i bought the new remote control and it did work at first i thought it was going to do the same thing but then i pushed the tv/use button and it worked perfectly.
Mar 13, 2009 | Haier HP42BB 42 in. Plasma TV
BenQ PDP-46W1 46 in. HD-Ready Plasma Television Logo
227 people viewed this question
Top BenQ Televison & Video Experts
ismash55
Joaquim Martins
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
