Question about Breadman TR520 Bread Maker
Dough leaks out under baking pan. Need new pan? new seal?
  • cstall Apr 21, 2009
    This is a great machine. It still works well, heats, rises, bakes, etc. The seal under the breadpan now leaks out dough and that seal is not replaceble. So sorry to put it in the landfill after such good use over the years and countless loaves of bread. I have the instruction manual and it is 1998 TR333. It has one recipe and it is a perfect, unfailing buttermilk loaf. I will try it in my new machine. cstall
  • 906 Answers
Good day,
hope this link below will solve your problem.
baking
Posted on Aug 05, 2010
Do I need to spray the well of the baking pan
No, not a good idea as that is where the heat is. You will just make a burned on mess. You only spray the inner pan where you put your ingredients.
Apr 23, 2016 | Kitchen Appliances - Others
Mixing OK but not heating/baking
That's not a good sign. This will keep your bread from rising properly and baking, obviously.
If you are still under warranty, contact your manufacturer, otherwise, you can still use the machine to mix but you will need to use your oven to finish your bread.
If your bread is not rising in the machine:
  • Remove mxing chamber from machine
  • If the chamber is not removable, UN-PLUG THE BREAD MACHINE so the blades DO NOT TURN.
  • Be careful of the mixing blade in the chamber
  • Remove dough gently with slightly oiled hands into a lightly oiled bowl with room for about 2x the volume of the dough
  • Cover with plastic wrap to prevent the dough from drying
  • Place the bowl of dough in an unheated oven and leave the oven OFF
  • Place an empty lasagna pan in the cold oven on a shelf below the dough or on the floor of the oven if there are no exposed elements
  • Boil some water and pour it carefully into the lasagna pan
  • Close the oven door - You have just made a proofing box. The steam and heat from the boiled water is sufficient to make a great proofing cabinet out of your oven hot box
  • Allow the dough to rise to about twice the original volume
  • remove the dough from the oven and remove the pan of water
  • continue with the baking instructions below
If your bread is rising in the machine or you have finished the above instructions:
  • Remove dough gently with slightly oiled hands into bread pans. Breadmakers are different sizes so you may need to use one or two pans. Or make an artisan style loaf on a cookie sheet lined with parchment.
  • Be careful not to compress your risen dough as this will make the loaves dense
  • You may also choose to make buns by separating the dough into smaller balls and placing on parchment lined cookie sheets
  • You can allow the dough to rise again for a short time in the proofing box above but I would just leave them on the counter under clean towels to prevent drying for say another 20 minutes. Over-rising bread should also be prevented. The result will be 'deflated' looking bread.
  • Preheat your oven to 375F and bake the bread until it is golden and makes a hollow sound when thumped on the top or the bottom crust
Personally, I love that a machine will mix and knead my dough for me while i go do something else but I don't like the appearance of a machine baked bread. I like the artisan hand-made look. I recommend you keep the breadmaker until you find one you like that is drastically reduced in price and just use the artisan proofing & baking options above.
If you have a Pizza Stone, you can also try that for baking an artisan bread. Use the breadmaker as the workhorse, use your oven as an artist.
Good Luck and may the Yeast be Lively!
Apr 02, 2015 | Kitchen Appliances - Others
Where is the ol coming from?
There is a rubber seal in the bottom of your pan that has failed. There is grease under that seal to keep the spindle that turns the paddle lubricated. If your breadmaker is still under warranty contact Cusinart to get help. If it is no longer under warranty then you could still probably order a new pan from them. If you just want to get rid of the darn thing you can always send it to me. At least that way it won't end up in a landfill. You can reach me at daryl441@msn.com
May 30, 2013 | Cuisinart CBK-200 Bread Maker
My Breadmen Plus has lost the ability to seal at the base at the o-ring. The inner seal is beginning to swell and is slowly leaking out past the bushing. It looks like "moly" grease. Is there a...
Most household appliances cost more to repair than replace. I suggest purchase a new one.
In the interim you can use this recipe to make fresh bread.
Add 1 pkg yeast to a cup of warm water with teaspoon of sugar. Let foam 15 minutes. Then add 3 cups bread flour and form a dough. Sprinkle the dough with half teaspoon of salt. "Knead" the salt in.
Place in loaf pan. Let rise until doubled, bake at 300 until done, about 50 minutes.
Nov 29, 2017 | Salton Kitchen Appliances - Others
The spindles that you attach the paddles to is leaking a black lubricant or something like that. I was making a simple sweet dough. By the way, I NEVER bake in the bread maker. I only use it to knead the...
Your machine has a lubricating grease that is under the small gasket or washer at the bottom of the pan under each paddle. After a lot of use the little gasket can fail and the grease can get get past the gasket and into your bread. The best thing to do is either replace your pan with what is called a "pan assembly which will include everything but the paddles. If you decide to do that be sure to keep your paddles. The other choice of course is to replace your machine which might not be a bad idea if your machine has been used a lot because you would have a new pan assembly but older parts may begin to fail such as the drive belt. Bread machines aren't all that expensive anymore so you may want to go ahead and replace especially since you just use your machine for making dough.
Feb 08, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
My bread machine is putting out oil in the bottom where the agitator is & it gets on the dough. Is my machine getting ready to break down ?
HI, There is a sealed bearing on the bottom of the bread pan. The seal has broken, allowing the lubrication to leak out. You don't need a new machine, just a new bread pan. Check on eBay or Amazon. If you are lucky you may find one there. Hank
Nov 29, 2010 | Welbilt Kitchen Appliances - Others
Defective
Hi, the seals can not be replaced. You will need a new bread pan. If under warranty you can get pan replaced. Sorry Hank
Mar 28, 2010 | West Bend 41090 Bread & Dough Maker
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
Sep 21, 2009 | Kitchen Appliances - Others
Black goo type liquid oozing from under dough hook when done.
Sounds to me like your seal is bad and you need a new bread pan, which includes the seal. Call phone no. in your manual to get the part you need.
Dec 06, 2008 | Sunbeam 5891 Bread Maker
Breadman TR520 Bread Maker Logo
53 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
