Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
The hoover shampooer will not extract the water from carpet, is it because the carpet is so low ?? the carpet is cleaning fine there is VERY poor underlay and then wood under that, worried about the wood getting wet and not drying out HELP
  • 281 Answers
Do you have suction at the front of the base,if you don't then look at the plastic cover on the base,you should be able to see through the plastic.the suction slot on the bottom front of the base is very narrow.i don't know if you have pets but most of the time the suction chanel gets clogged with hair and dirt.the chanel is right up the middle on top of the base.look in there and see if you don't see a lot of hair and dirt stuck up inside.there are some screws on the bottom that you need to take out to remover the cover.then the cover comes apart in two pieces to allow you to get to the suction chanel.please leave some feedback.i hope i was some help to you
Posted on May 01, 2009
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed ' http://www.babayans.com/en/
May 01, 2014 | Vacuums
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
My Hoover SteamVac Max Extract 77's dirty water tank won't fill. The water seems to just filter right back to the floor. What do i do???
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
Jan 22, 2011 | Hoover F6055-900 SteamVac Maxextract LS...
I have a Hoover Deep Clean carpet shampooer but can't find the instruction manual
Click on the following link and scroll down the list of Steam Vac models to find your specific one. Then click on the red characters which represent your hoover situated to the left of your specific model:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Best wishes,
Graemevm
Jul 03, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac isn't extracting solution from carpet. Motor runs and the brushes weren't turning at first but do now
That vacuum is fine on liquid extraction but often gets clogged by debris when it hits a solid. It would be better to do the clean with the steamvac then follow it with a wet/dry shop vac to be sure you got all the water. I say this because the vac built into that hoover is way too easy to clog.
Mar 13, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
NOT SUCKING UP THE WATER
The Kirby shampooer isn't designed to be a extractor.What the shampooer does is create the foam,and the brushroll on the shampooer works it into the carpet.After the carpet is dry,(about an hour,)switch to the vacuum,and the vacuum picks up the dry foam.
Dec 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
Not sucking at full power. lines are clear. don't understand.
It would help to know what brand of machine you have and if it's a vacuum cleaner or a carpet shampooer.(It sounds like a shampooer.)
Feb 22, 2008 | Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
248 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
