Microphone Problem I plugged in a microphone into my HP Computer and I can't figure out how to record something?
SOURCE: No Sound Coming out my Microphone
This same thing happened to me. All I did was plug the mic into my keyboard, turned the mic volume to max, and turned the mic on. Then, I grabbed the part of the mic where the cord goes in, and started turning it. I turned it left and started hearing noise come out of the mic. I kept on doing this, until sound came out of the mic. I did this, and now the mic works again. Hope this helps!
Posted on Dec 22, 2008
  • 23 Answers
SOURCE: Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Posted on Aug 02, 2009
SOURCE: Sound problem
ok well u need to save the music first den export it n save it on to ur computer den open it wit ur windows media player or wich ever player u have
Posted on Aug 10, 2009
dnewcombe1
  • 1564 Answers
SOURCE: GE PC Microphone with detachable laptop mic - does not work
Go to your default settings menu at the very top of the menu in the all programs. Check in there and make sure that your default recording device is the GE Microphone, if it is not, make that the default.
Posted on Sep 08, 2009
  • 11 Answers
SOURCE: Dimension E310 Microphone
its on the back on mine but if you dont have one you could get a usb mic
Posted on Dec 23, 2009
I'm having trouble with figureing how to set up my microphone to the computer
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable Hope this helps.
Dec 12, 2012 | Dell Dimension 4600 PC Desktop
My microphone not working
Dear,
Hardware troubleshooting Depending on whether you are using an internal or an external microphone, follow the steps below to see if the problem is with the hardware.Show all ' Hide allcollapse_individual_default.pngTest the internal microphoneThe internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to capture sound more easily.
  1. Adjust the notebook screen to place the microphone in the best direction for receiving sound.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. When using the internal microphone, choose an environment without background noise.
  6. If the recorded sound does not play back, continue to the next section of this document.
collapse_individual_default.pngTest the external microphoneVerify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
collapse_individual_default.pngSet the default microphoneIf the external microphone is set as the default recording device, uninstall and reinstall the audio driver to change the default recording device to the internal microphone. The internal microphone should be the default recording device.To change the default recording device:
  1. Click Start , enter device into the search field, and then select Device Manager from the list.
  2. Expand the Sound, video and game controllers list.
  3. Right-click the audio driver , select Uninstall from the drop-down menu, and then click OK to confirm that you want to uninstall the audio driver.
  4. After the audio driver is uninstalled, click Start , enter backup into the search field, and then select HP Backup and Recovery Manager from the list.
  5. Follow the on-screen instructions to reinstall the audio driver.
The internal microphone is now set as the default recording device. Basic troubleshooting
The following are some basic troubleshooting tools that you can use to restore your microphone's functionality, depending on your operating system and/or software preferences. However, it is recommended that you first run the HP Support Assistant as it can scan your current system configuration to automatically determine if your notebook requires updated software and device drivers.
Mar 09, 2012 | HP Compaq d530 SFF PC Desktop
I can't seem to figure out how to record anything from the the microphone or otherwise. Any suggestion or instructions?
We just got one of these today at a thrift shop. I thought it was supposed to record what you say into the microphone but it doesn't. It records your "compositions". Press "record" then play something on the keyboard. Then hit "Play" and it should play it back for you.
We can't figure out how to get the darn microphone to work. Is it supposed to work or is it just for looks?
Jul 01, 2011 | Battat B. Meowsic Kitty Kids Keyboard
I have a HP laptop, and the internal mic has never worked? is there an upgrade i need? also, is the sound card automatically in the computer or is that something extra? i thought since it had the internal...
Changes in software, settings, or drivers can cause a microphone to stop working. Before performing any of the solutions in this document, test the equipment. After testing the equipment, select the document section that applies to the issue and follow the instructions. If the microphone recently stopped working, it may be necessary to use the Microsoft System Restore feature to correct the problem. Windows Troubleshooting Windows troubleshooting can automatically fix common problems with your computer, such as audio recording. Although it may not fix every problem, it is useful to run Windows Troubleshooting first before you manually correct problems. To run Windows Troubleshooting, follow these steps.
  1. Click Start , enter troubleshooting in the search field and select Troubleshooting from the list.
  2. Under Hardware and Sound, click Troubleshoot audio recording and then click Next when the Recording Audio window opens.
  3. Select the device you would like to troubleshoot and then click Next .
If a recommended action displays, select Apply this fix or Skip this step to continue to search for other problems. If your problem has not been resolved, continue to manually troubleshoot using the rest of this document.Test the equipment Verify that the microphone port and the microphone are working properly.
Dec 01, 2010 | HP Pavilion dv2000t Notebook
Ok i have a compaq computer (vista) and when i plug in the microphone it say's it's operating but when i go to record it does not play any sound. but when i go to plug it in into my other computer it works...
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Jan 06, 2010 | Samson C01U Consumer Microphone
Logitech Microphone 600 - not working
Not sure the problem is in the driver. Just bought the microphone and probably don't know how to use it. My computer has a sound recorder but I can't get any audio? I think I just don't know what I am doing.
Oct 13, 2009 | Computers & Internet
Aug 02, 2009 | HP Pavilion dv6000z Notebook
How to record audio using microphone input
What is the Make / Model of your Laptop? Depending on this, there may be an internal Microphone built into your computer you could use. If not, I can also show you how to specify windows use the "Microphone" as the input device.
Typically Laptops have 2 input selections "Line Input" and "Mic"
Line input is for use when you want to say.. Hook your ipod up to your laptop.
Microphone is a little different, as the input looks like the same as the other Line Input place, however the Microphone port provides power to whatever is plugged into it, which will cause problems if you plug anything other then a microphone into it.
And vice versa, if you plug a microphone into the "Line In" port, the microphone will not work, because the "Line In" port does not send out power to the microphone. Inside Windows Audio if you click 'Options' then properties, click on the recording tab, after this, make sure all the available check boxes ARE checked. Click OK. Then Find the MicroPhone Slider bar, Make sure it is towards the top, and also the checkbox marked "select" is checked. Then go back to Options - Properties - Click Playback, and ok.
Any other information you could provide will make for a better solution I will follow up on.
Mar 14, 2009 | HP Compaq Presario V2000 Notebook
Microphone plays my voice but doesn't record it
I agree with anuragmi but also want to add check that mic is plugged into the input of the soundcard and if all else fails try it on someone else computer and if it works there is an issue with your soundcard or settings. Good luck.
Sep 19, 2008 | Logitech (980240-0403) Microphone
Microphone port not working
in advanced settings there would be options for microphone boost and something else...disable both...i dont know the reason why this happens but mic doesnt work with those options enabled....
Dec 05, 2007 | ASUS A8N-VM Motherboard
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
