Question about Garmin nuvi 350 GPS Receiver
Garmin 360 will not boot
When pushing power button, "Navi" screen comes up one second then turns off.
  • kenw1215 Apr 14, 2009
    Sorry didn't work, now won't even boot.
  • kenw1215 Apr 17, 2009
    bunnydawg, I can't thank you enough!
    Brigadier General:
  • 5,158 Answers
There is a button on the edge of the gps that you can hold down with the point of a pen or pencil... hold that down for about 20 seconds to reset it. let me know how that goes
Posted on Apr 14, 2009
  • Roberta Smith
    Roberta Smith Apr 14, 2009
    you have to raise the antenna and the reset button is located behind it
  • Roberta Smith
    press the reset button again once.... it should still be able to boot
It is stuck on the Garmin screen
Most likely a boot-up issue. Please see this link for more info on this problem. Typically caused by a corrupted map or system file.
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Jul 03, 2015 | Garmin Nuvi 50 LM
Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Sep 30, 2008 | Garmin n vi 360 GPS Receiver
When turning on our Barmin Nuvi 1200 it takes at least ten minutes for the navi to start. The screen just shows ; Loading maps.
You can try to reset the 1200. You can reset by pressing and holding the power button until it reboots.
If that does not work you can try a hard reset but it will clear out some of your favorites and saved locations back to like when it was new.
Power off the unit; then while holding your finger on the lower right corner of the screen while turning it back on.
Keep your finger pressed until a window appears. Choose YES to clear all data and return the 1200 back to factory settings. I will attach the Garmin customer support info.
Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 17, 2011 | Garmin nuvi 1200 Car GPS Receiver
Garmin navi will not connect to computor so i can register
You may need to replace the usb cable that you are using to connect this device to your computer.
There's just 4 steps on how to connect garmin navi to computer.
1. Connect the mini-USB end of your USB cable to the back of the Navi.
2.
Turn on your PC and connect the standard USB end of your USB cable to the USB port on your personal computer
3.Power on the Navi and give the computer time to recognize the device.
4.Click "Start," then "Computer." The Navi hard drive should be among those listed under "Devices with removable storage." You can click on the Navi's drive icon to access your Garmin device
Dec 26, 2010 | Garmin nuvi 255W GPS Receiver
Garmin 178C Boots up then shuts off
I've had a similar situation with a Magellan, it would power off despite being plugged in.
Its usually a battery issue, perhaps its not getting enough power? You could try to unplug it and do a "hard battery reset" depending on the type of battery. Keep turning it on and let it run out, until it wont even turn on anymore, after that plug it into a charger while off and allow it to charge completely. Turn it on, see if it still shuts off.
May 26, 2009 | Garmin GPSMAP 178C GPS Receiver
Firmware Update
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below and you must use it:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Garmin Communicator Communicator Plugin is properly installed and up to date, version 2.9.1.0. (Dec 21, 2009) If after following all the above the final steps would be to perform a master reset.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes, and wait
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Mar 26, 2009 | Garmin nuvi 260W GPS Receiver
Check the pins at the connector on the back of your unit. Make sure one of them is not bent or broken off. One of the pins on mine is missing about 1/16" of the tip. My boat repair shop says it's the power lead, but Garmin wants $200 for a generic repair.
Oct 18, 2008 | Garmin GPSMAP 178C GPS Receiver
Garmin nuvi 360
Have you tried pushing the reset button on the back under the antenna?
Try turning it on and listen for any sound, like the start up beep. Do you hear any sound at all after 30 seconds?
There's a couple possibilities that could have happened.
1. The screen and/or main board has been damaged.
2. The screen cable has come loose from the main board.
If the unit is under warranty (registered with Garmin) you can call them and see if they will fix it for you. They may charge you if they determine it was dropped or mishandled. www.garmin.com
If you have problems with getting them to fix it for you, I'll be happy to look at it for you and give you a quote. I have repaired many Nuvi's and I have references.
If interested, please email me at ks3r at sharc dot net.
- Jim
Sep 09, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Jun 29, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
