Question about Samsung Digimax 401 Digital Camera
Memory card error
My samsung digital camcorder scd 103 is reading memory card error
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 23, 2010
Memory card error
When you tried to format, did it complete formatting? If format failed then the memory is bad. Buy a replacement. Format should be completed in the camcorder for it work right.
If format completed, and you can write to and read from the memory card on the PC, then there may be a problem with the camcorder card reader. Try blowing out the card slot with canned compressed air. (Don't use a tire inflator) And gently wipe off the contacts on the card with a QTip dipped in alcohol. Good luck.
May 12, 2013 | Samsung SC-D103 Mini DV Digital Camcorder
Can i use a 2gb memry stick for samsung scd 103? thank you
Yes, but memory stick only use to save only for still images not for movie purpose.
Thanks.
May 14, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
I am trying to find a SD card that will work in my Samsung Digital-cam Model: SCD 103. A regular SD card will not fit in the slot on my camera. The manuel just calls for a SD card. I need more details.
The SC-D103 doesn't take SD cards. It takes Sony Memory Sticks and compatibles from third-party manufacturers such as Lexar and Sandisk. Be careful, it will not take Memory Stick PROs.
Oct 09, 2010 | Samsung SC-D103 Mini DV Digital Camcorder
What kind of Memory Card do I use in my Samsung Digital-Cam 103 I got 8GB, It will not fit in the Slot of the Camcorder
The user manual is here http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=04020100&prd_mdl_cd=&prd_mdl_name=SCD103
the 103 model is limited to the Sony Memory Stick - see page 82 of the user manual and can NOT use the Sony Memory Stick PRO or any other format of card.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 05, 2010 | Samsung SC-D103 Mini DV Digital Camcorder
NEED OWNERS MANUAL AND ACCESSORIES SAMSUNG SCD103
i have this vedio dvd cam this does not go to play mode.it always says eject c(model # SC-D6550
May 28, 2009 | Samsung Video Cameras
Battery not charging
You may have a bad battery! (this is the number 1 cause of this problem!) a battery can go bad overnight!
Please rate my response!
Jan 16, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
NO DISPLAY ON LCD IN CAMERA MODE
i have this same problem for a while and just stumbled on the (yet to be verified) solution. www.samsungclassaction.com. if this settlement is legitimate then Samsung will repair for free! (and refunds for people who paid Samsung to repair). the site asks for contact info but i worry about scams so i'm going to contact Samsung directly.
i hope this is real!
The affected models include:
SCD 23, SCD 27, SCD 103, SCD 107
Nov 07, 2008 | Samsung SC-D107 Mini DV Digital Camcorder
Memory card error
did you already formated your memort stick? try to remove your memory card from your camcorder and insert it again. look for the settings on your camcorder. it might cause the problem. hope that helps!
CHARCOIS
Aug 17, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Shutter dosen't open, Black Screen while recording
there is a couple other posts on Fixya regarding this issue, the CCD sensor going bad and resulting in no image. i have the same issue and i just stumbled on the (yet to be verified) solution. www.samsungclassaction.com. if the settlement is legitimate then Samsung will repair for free! (and refunds for people who already paid Samsung for repairs). the site asks for contact info but i worry about scams so i'm going to contact Samsung directly.
Dec 31, 2007 | Samsung SC-D107 Mini DV Digital Camcorder
Samsung scd103 camcorder memory card
From the manual:
“Memory Stick PRO” can not be used with the SCD103 MODEL.
You MUST use only a memory stick, not the PRO
Nov 18, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung Digimax 401 Digital Camera Logo
171 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
