Question about Ricoh Aficio 450 Copier
Repair of xerox copier 5334
This message is displayed: Paper tray is open. Close tray2/tray3 drawer.
  • 30 Answers
Most of the time this indication comes from having a piece of paper lodged behind the paper drawer, blocking the paper drawer sensor, giving this indication. Remove the paper drawer and look into the cavity and you should be able to see the paper and remove it.
Posted on Sep 13, 2007
  • 163 Answers
The sensor board of trays is abnormal check it
SOURCE:
Xerox 8570 tray2 issue pickarm stuck
the problem of your machine is mechanical you must change your gears found on your machine.
Sep 06, 2016 | Xerox Corporation Xerox ColorQube 8570DT...
I have (caution) tray2 open close tray2 can you help to close tray2
sir Check the sensor for tray #2. Another remove the tray #2 check for broken acturator and or broken tabs that go into the machine to indicate the printer draw two is closed. Lift the printer off tray two use just one and bypass does that work eliminates the circuit board of the machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 30, 2015 | Konica Minolta Magicolor 4690MF...
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
How can I get the paper drawer for my Xerox Phaser 4600 to open? The paper tray is empty but won't open.
Hi Anonymous,
I suspect you must have solved this one by now.
I can only assume you have something jamed inside. (your thoughts too I expect)
I would have thought removing as many panels as you could to gain access to the drawer unit to add paper might reveal where the problem might be!
Good Luck.
Jul 02, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
We have a xerox 3250 printer and it keeps telling close tray. tray is closed seems the detector does not work, where can we find the tray close detector/ Regards, AREXX
1. Power off the device.
2. Unplug it from the wall.
3. Leave unplugged for 5 minutes
4. Plug it back in and turn it back on.
5. Test
If it still does not sense the tray you will need to engage service.
Jun 30, 2011 | Xerox 250 Sheet Optional Paper Tray Feeder...
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Ricoh Aficio 450 Copier Logo
150 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
