dual xia3145 blowing fuses. I took sub out to go shopping. came back home, hooked up sub... poof! of the three fuses, the 2 20amps blew, not the 5amp thats on the left.
GM09SR installed April 2009 in 2006 Trailblazer, Radio sometimes will not turn on/off when key is...
(More)
GM09SR installed April 2009 in 2006 Trailblazer, Radio sometimes will not turn on/off when key is turned on/off, the chimes quit working, etc. When this happens I can "reboot" by disconnecting the car battery cable, after which the Chime and other functions return to normal. Radio used with this is Sony MEX-BT3700U, replacing GM factory basic radio (no bose, satellite, etc) After disconnecting power at battery I have to re-enter all the radio button station presets, bluetooth pairing, etc. Is there a known specific cause, and solution other than disconnecting battery cable?
Pontiac,monsoon delco seven band equalizer. keep saying er20 sometimes it works when its warmed up....
(More)
Pontiac,monsoon delco seven band equalizer. keep saying er20 sometimes it works when its warmed up. in cold weather its worse.
