try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? good luck
I would check the bios and see what the shutdown temps are for the cpu as they may be set too low ( check the manuals for the cpu's as you dont want to set it too high as obviously if it does get too hot you dont want the cpu's ( processors ) to blow up or die on you.
probably not , each motherboard has a certain setup for the ram slots , best to ask your computer parts store for the best ram for your motherboard , they can also give you a deal on used ram
U do a flasing of ur BIOS, there will a jumper on the mother board, U can find it refering the manual of ur mother board, jst change the jumper to flash the BIOS, then try booting...
well, turbocad deluxe 10 is NOT compatible with vista. Here is the compatibility list :
Windows 98/Me/NT4/2000/XP
Pentium-class PC
64 MB RAM (128 MB recommended)
55-212+ MB hard-disk space
64 MB of swap space
Super VGA (1024 x 768) display
High Color (16 bit) graphics card
4x CD-ROM drive with 32 bit drivers
