Question about Sharp R-1480 Microwave Oven
Sharp microwave is suddenly dead. 120 volt power is OK
    Scholar:
  • 192 Answers
It sounds to me that the fuse has blown out. this could be fixed at home if you are handy. You don't have to be super handy .I can walk you through this repair. DFD
Posted on Apr 14, 2009
My sharp R-352DC Microwave won't heat, and turntable doesn't turn, also the display does not work. Please tell me the problem?
It sounds like power to the circuit board might be interrupted, but data on non-US models is limited.
Nov 17, 2016 | Sharp Microwave Ovens
Sharp Carousel 2 R-8475A
power to microwave gone wall switch has 120 volts
May 09, 2014 | Sharp R-9H84B Microwave Oven
What is the wattage on the sharp microwave model r-2a48?
http://www.sharpusa.com doesn't have your manual. But you can find it yourself on the
back of the unit - the wattage should be listed.
If only the amperage is given (you know the voltage is 120 VAC RMS), so using Ohm's Law, you can calculate wattage:
Watts = 120 Volts X Amps
May 13, 2011 | Sharp R-2A48 Microwave Oven
Microwave is totaly dead
YOU WANT TO CHECK POWER FIRT AT THE OUTLET MAKE SURE YOU STILL HAVE 120 VOLTS THERE.. IF SO AND PLUG IS GOOD ON 98% OF THE MICROWAVES OUT THERE IS A 20 AMP fuse located in control panel of unit... check there with the power disconnected and may have a blown fuse...if that is good you most likely have a blown control on unit ...
hopw this helps good luck...
Jan 05, 2011 | Hotpoint RVM1325BW Microwave Oven
The microwave is absolutely dead as if getting no power - circuit breaker is OK. Died suddenly...just nothing there when tried to use.
Possibly the internal fuse. Unplug unit, remove all case screws on the back of the micro. Slide the case toward the back and remove. Look for a glass tube type fuse, simular to automotive fuses of the past. It should be located near the controls. If bad, I have been able to find replacements at Radio Shack. If the fuse is good, I'm sorry, it's beyond my microwave knowledge level.
Jan 03, 2010 | Sharp R-1460 Microwave Oven
Ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Unit is dead, no display no turn on Worked fine one day, dead the next
it maybe the internal fuse tht has blown all microwaves have a monitor fuse inside some where the mains power comes in and some on the control pcb it does mean that a short circuit has accured but it can happen if the door is slammed you will need to remove the top cover of the unit to find the fuse and be very careful inside everything is very sharp and door make sure it is unpluged also inside a microwave i a large capacitor this can store power even with the unit off it should be grounded b4 working on the unit but a long as you are just changing the fuse you should ok do if you can use insulated pliers for your own safety,if u fit a new fuse and it blows again thn my advise would be to take it to a a repair shop as the high voltage side of your microwave is up to 4000-5000 volts
Oct 20, 2009 | Emerson MW8987B/W Microwave Oven
TOTALLY DEAD
CHECK THE FUSE ON CONTROLL BOARD, CHECK THE CONTINUITY OF THE LOW VOLTAGE TRANSFORMER.
May 02, 2009 | Microwave Ovens
Where are gound fault outlets located on holiday rambler 2009
check the breakers on the inverter located in the outside compartment it has two breackers on it. most people don't know that some of the 120 volt power comes thru the inverter.
Mar 23, 2009 | Sharp R-1874 Convection/Microwave Oven
Sharp R-1480 Microwave Oven Logo
196 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
