Question about Ruud UAKA030 Air Conditioner
Major condensation comes from my gas heater
I a gas heater that needs a condensate pump which is constantly full. The pump recently went bad and caused a small flood. What causes so much water to accumulate in the winter
    Novelist:
  • 189 Answers
Gas heat is a moist heat. The products of combustion are condensating in your secondary heat exchanger. This is normal on a 90% or higher furnace. Open up the top of the condesate pump. You "might" just have a sickty float. If so clean it up and start adding a halve a cup of bleach a couple times a year to prevent slime build up.
Good luck......
Posted on Apr 14, 2009
Disconnected condensation drain on hot water heater.
Tankless or hybrid water heater?
Tankless gas must have special fitting between water heater and vent that has a condensate line fitting. Hot toxic vent gasses traveling up vent pipe cause acidic water vapor to form inside vent pipe that drips back down vent and drips onto heat exchanger and other parts eventually burning hole through expensive metal alloy heat exchanger, rendering tankless computer water heater useless after electric circuitry gets wet and shorts out.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#vent
Hybrid or heat pump type computer water heaters must have condensate drain connected to catch pan located just above storage tank and below compressor. Condensation can form on condenser coils and drip into catch pan where there is primary and secondary drain
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#maintenance
Read product manual
Gene
h
Apr 17, 2014 | Water Heaters
Corroding top of rheemglas 21vr50-2t
Corrosion caused by condensed acidic water dripping down vent pipe, bad venting pushing acidic combustion by-product out of vent hood, trace chemicals stored in same room as water heater, dielectric corrosion because water pipes not grounded, hot water pipe above tank is not insulated and condensation dripping down on top of tank ... are things that come to mind.
Test venting:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#vent
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Mar 26, 2013 | Rheem Water Heaters
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
I have a 5-year old Goodman furnace/AC. It has a drain trap on the side which looks like a cup with 2 hoses coming into it from and a drainage pipe coming out into the sump pump. Recently I noticed a...
Hello, it sounds like your condensate line is clogged and not be able to drain into the condensate pump or your condensate pan is cracked and leaking. Best thing to do is clean the condensate line with a shop vac and see if the water will start to drain, if not looks like the pan is cracked.
Jul 13, 2011 | Goodman GMS90703BXA Heater
Our MGTA 07 EMAES Dayton gas furnace has a crack in the condensate pump. Where can we find a replacement?
Hello, here is a link to where you can purchase condensate pumps http://www.plumbersurplus.com/Cat/Condensate-Pumps/284/List
Jun 08, 2011 | Dayton Gas Furnace Heater
Installed upgrade to water heater and piolet light lit fine. for a minute the flame turned yellow as condensation driped but when it stopped flame went back to blue.
New gas water heaters drip condensation the first time they are lit.
The dripping stops.
You should be fine.
Keep us posted.
You can add a comment and I will help further if needed.
Nov 03, 2010 | Whirlpool Water Heaters
Worcester combi gas boiler 3.5 highflow is constantantly dripping water at the external flue position over flow pipe
water vapour is one the main products of combustion of gas. With a standard efficiency boiler, upon initial heat up when the flue is cold this vapour can condensate on the inner wall of the flue but should stop once the flue heats up, to stop this condense dripping back on to the heat exchanger the flue should be tilted towards the outlet and thus on initial heat up water can drip from the flue. with high efficiency (condensing) boilers, condensation will occur in the flue and secondary heat exchanger during normal operation, dispense of this condensate is accommodated for in the boiler and therefor the flue should be tilted towards the boiler, if not the flue will drip constantly.
Apr 06, 2010 | Water Heaters
Leaking water
how long have you had the unit,, depending on where you live you might be using your ac in your house and if the installer didn't install the condensate catcher on the flu pipe then you wil have water runing out of the unit, if it is happening all the time then you would need to have a service tech come out that would meen something like the tank or a water line is broken,, but since you said it's coming from the side I would have to say it is condensation
Jun 04, 2009 | Goodman GMS90703BXA Heater
My Honeywell 8501 thermostat has
Ceck for a full condensate pump or a float switch at the drain pan. In most cases we set these up that way to make you aware of a problem. Often the condensate pumps get slimy and need to be cleamed yearly.
Dec 11, 2008 | Honeywell Electronic Programmable...
Goodman furnace may be producing to much water
Your furnace is more than 90% efficient and extracting so much heat from the gas that it condenses instead of blowing out steam. This is good! Figure that for every dollar you spend on fuel, you are getting back 90+ cents back in heat. Compare that to the typical units that only get 70 - 80 cents back in heat.
Yes you should drain your condensate to a proper drain via gravity or a condensation pump. I would recommend you treat the condensate first with a acid neutralizer prior to draining in municipal drains due to it's high content of sulfuric acid. You can purchase these filter type neutralizers on the net or at a good heating wholesaler.
Feb 11, 2008 | Goodman GMS90703BXA Heater
Ruud UAKA030 Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
