Question about Garmin zumo 550 GPS Receiver
Display The display dose not auto dim at night. I have the color mode set to auto. How can I get the zumo to auto dim? How do I reload MapSource? Can I just up grade to a newer version?
    Scholar:
  • 174 Answers
It does not auto dim, it just remembers the settings. As soon as it has a GPS fix and knows the correct time it will switch to either day or night mode, and use the last setting you chose for that mode. Just give it a minute or so to get that GPS fix.
Mapsource, you mean the one on the PC? That you can upgrade by downloading it from Garmin, If you mean the maps on the GPS, you gave to order the DVD from Garmin and pay for the unlock key.
Posted on Jun 10, 2008
Why does Garmin nuvi 1250 power on but dim to almost black when plugged into power outlet?
Make sure you have your time and time zone set to match your area. Also look in display settings to see if it is set to night mode versus auto adjust.
Jun 28, 2014 | GPS
Display is very dim in the daytime.impossible to see anything
Do you have the display lighting turned down, there is a control for the brightness.
Aug 17, 2012 | Cars & Trucks
Display stays in nighttime mode, does not return to daytime mode when daylight
Please check the display settings, it can be set to day , night or auto in Tools>Settings>Display then Color Mode.
See page 39 of the attached manual link below.
Thanks for using FixYa
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Sep 23, 2011 | Garmin nuvi 1300 Car GPS Receiver
Nuvi 205w screen won't light- any ideas? it's brand new and fully charged. I can tell it's on, because it generates sounds when I touch the screen.
If you can't see anything then it is a hardware issue. Return for replacement as soon as possible.
If you can see faint images in the background then your screen is just too dim. You will have to try to navigate the dim screen to the settings menu. Click on the Tools icon, bottom right of main screen. Click on "settings" then "display". Select brightness and adjust.
One other suggestion is try an update. Plug the unit into your PC and run garmin webupdater. Once done the screen may light up but its a long shot. Here is the webupdater link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Cheers
Jul 13, 2010 | Garmin nuvi 205W GPS Receiver
Dim Screen on the 2001 Toyota Prius
Yes the screen dims automatically when the lights are on to suit night driving. I am not specifically familiar with the 01 model, however on my 08 model, the display brightness is also manually adjustable via a button located below and to the right of the display. The button is marked with a series of short lines assembled in an arc. Hope this helps.
Nov 25, 2009 | 2001 Toyota Prius
Delphi XpressRC XM Radio backlight problem
Same thing happened to mine until it permanently went dark - no brightness. Problem is with the LCD display that is defective. As this model does not have a separate filament bulb unlike the non color model, it cannot be repaired. Likely too expensive to replace the color LCD display if avalaible. Next one I buy will be a non color version which has separate bulb.
Sep 17, 2009 | Delphi XpressRC XM Satellite Radio...
Dim Mode
Make sure the orange wire with white stripe is connected to your dash illumination/parking lamp circuit. There should be a tag on it that says 'ILLUM' (unless the installer clipped it). That should dim the display whenever your lights are on.
If that doesn't do it enough I think your going to have to dial down the brighness - and that will do it for all functions.
Feb 13, 2009 | Kenwood DNX7100 Car Video Player
Garmin zumo 550 map update problem
  1. Make a backup of your Zumo by copying all the file to your computer.
  2. Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
  3. Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
  4. If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
Jan 09, 2009 | Garmin zumo 550 GPS Receiver
Garmin Windows Vista Issue
I now this issue, and it's quite easy to work around, right mouse click on the executable and select run as administrator.
Aug 28, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
190 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
