Question about Refrigerators
Every 45 minutes it makes a buzzing sound like an alarm clock
About once every 45 minutes it sounds like an alarm clock. It buzzes for about five seconds.
Bogdan
  • 198 Answers
SOURCE: I get a buzzing sound
Hello Rrosario35, This problem is related to the lens assembly. The camera will check if these work properly when it's being powered on. If something goes rong here it will turn off or display you some error messages. This problem occures when some of the lens mechanisms get out of place and jamms or damages other components. As the lens assembly is a very delicate mechanism I would suggest you to go back to the service center that fixed it the first time and ask them to check it. Don't try to power the camera on anymore because the lens assembly could be damaged further or beyound repair if the servo-motors are trying to alling the lens something jamms them and not allowing them to move properly. This will force the servo-motors and they could damage other components or themselves. It could be fixed, but don't force the camera to work anymore for the time being. Please post back if more informations are required.
Posted on Mar 23, 2007
hotuna
  • 288 Answers
SOURCE: Buzzing sound
the buzzing sound is the compressor trying to start. Unfortunately, it is locked up and the overload is cutting it out. It resets every couple of minutes or so. The problem is the compressor. You can try a hard start capacitor to see if it breaks loose, this is the cheap fix, otherwise it needs a new compressor, the expensive one.
Posted on Dec 05, 2007
  • 4 Answers
SOURCE: Loud buzzing noise
oil the blade with clipper oil, a couple of drops on the teeth
Posted on Feb 04, 2008
  • 958 Answers
SOURCE: Buzzing sound and not cooling
it looks like you have a bad compressor. try replacing the ptc starter and the run capacitor, if it did not change anything, then you have a bad compressort that needs to be replaced. if those parts are expensive, test the capacitor by using an analog meter, test the terminal using the X100 resistance. the meter needle should indicate continuity and slowly goes back to infinity. then reverse the terminals to the test prods and it should happen again. then test the resistance of the ptc starter, it should have a reading between 20 ohms and 100 ohms. and there whould be no rattling sound inside the ptc starter. hope i was able to help...
Posted on Feb 12, 2008
SOURCE: Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
Call the manufacturer. Chances are it's a common problem and they already know about it.
Ben C.
BensDiscountSupply
Posted on Nov 04, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Turn off the alarm eaton viking stove
This did not work for me. The alarm won't go off at all. The dial for the clock seems very loose - it stuck many times when I was turning the dial to change the time, and then it just got loose, and now the alarm won't go off. Please help!
Jun 14, 2014 | Viking Stove/Oven/Range Timer Knob -...
Royal chiantishire buzzing how to fix
I have the same buzzing ticking clock sound much too noisy. Can't find a way to get to the clock
Mar 19, 2014 | SNK Fratelli Onofri Royal Chiantishire...
I can't figure out how to set the alarm and make sure that it's set. The instructions with the clock radio are not clear. Also not sure how to turn off the alarm when it buzzes in the morning.....Help!!
Hello Barb,
To set the alarm hold either alarm 1 or alarm 2 buttons down. While holding down the button adjust the hour by pressing the tune+ button. The bottom left of the display there will be a light letting you know if it is pm or am. While still pressing the alarm press tun- to select the minutes. If you want to wake with radio or a buzz keepholding the alarm button down and press the am/fm/aux button. Release the alarm button when done. To select an alarm just press the alarm botton you want once, a light on the right side of the display will turn on. To unselect press the same alarm button once and the light will turn off. To turn the buzzer off in the morning select power/al off button located at the top left of the unit.
Jan 05, 2011 | GPX C389B Clock Radio
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
BUZZING SOUND WHEN RUNNING
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
SHARPER IMAGE S1785 alarm BUZZ to SOOTHER sound
Johnny, push "mode" once. The alarm symbol blinks. It is also displaying the alarm mode. Pushing "display" changes the alarm source. Bill
Sep 03, 2008 | Sharper Image SI785 Clock Radio
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Sep 14, 2007 | Sharper Image SI686 Clock Radio
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
