Question about Dishwashers
Soap dispenser does not open during wash cycle
The soap dispenser does not open during the wash cycle. I also noticed that the control lock light is not illumnated?
    Sergeant:
  • 187 Answers
  • Hi,
    please try this...
    imer:
            On mechanical set ups the timer is attached to the detergent cup by an actuator arm. This arm is usually plastic, and if it is broken or otherwise defective then the detergent cup wont be opened. Check the linkage to make sure it is functioning correctly.
    Bi-metal switch or wax motor:
            The bi-metal switch is simply a very precise device that warps, bends, or otherwise deforms when power is supplied to it. The timer operates the bi-metal switch, which inside the dishwasher door. Then the switch is supplied with power and it is working properly, the bi-metal switch deforms away from the latch holding the detergent cup closed and the cup opens dumping the detergent into the washer.
            Some dishwashers have this switch wired through the motor power feed or the heating element. If they are defective then the detergent door will not operate correctly. If the switch itself is defective then you will need to replace it. Another type of mechanism is a wax motor. Wax motors are sealed units filled with wax and found in newer dishwashers and work by heating the wax and forcing up a piston which in turn mechanically opens the detergent cup door. This type of device is also controlled by the timer.
    Detergent cup:
            Sometimes the detergent cup becomes built up with old detergent that prevents it from opening correctly. It's usually a simple fix to clean this out. If cleaning it is impossible then you may need to replace the cup assembly.
    please rate my suggestion..
Posted on Apr 14, 2009
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Check the operation of the soap dispenser door for easy close and opening. If there is a relay problem or controller problem this could happen. You have to check all these points.
Sep 08, 2010 | Dishwashers
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
My soap dispensar inside does not open during wash
its just a bad (failed ) dispenser. replace it . this should correct problem . mm
Dec 07, 2009 | Washing Machines
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Jan 16, 2008 | Maytag 24 in. PDC3600A Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Soap dispenser drip
Normally you shut off the wall valve when you are thru with your washing. If there is a leak in the front area (important: first take the plug off the wall) open up the top of the machine and check whether the three rubber tubes are in place at the soap dispenser - one of them may have come off. Refit or replace if rubber tube is damaged; would be good to check all the tubes. Another thing would be to check that your soap dispenser is not clogged. :)
Sep 21, 2007 | LG WM1815CS Front Load Washer
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Dishwashers Logo
817 people viewed this question
Top Dishwashers Experts
