As it is freezing so soon after switch on - it isn't even trying to boot, a disc is unlikely to be much help because there is a chance your hard drive died.
I would remove the drive and use one of the inexpensive usb/hard drive adaptors with another computer to check the drive before doing anything else.
If the drive is ok either the Windows is seriously corrupted or the laptop has a hardware problem.
I never bother trying to repair Windows but back up what I want to save and format the drive and reload Windows and the other software. It is a lengthy job but it is the best way to clean the drive...
Ready mix is ok, but usually more expensive than buying the regular and mixing it 50/50 with distilled water. The ready mix is generally the same concentration as mixing your own 50/50. To be sure, check your 50/50 mix or the ready mix with a tester, it should register close to -35 degrees F.
When booting up the computer for the first time, it may ask you to set up an account with your password. At that time you can 'register' and activate your computer with Acer, but it should be connected to a WiFi connection at the time.
You might want to go into the bios to turn off halt on all errors,except keyboard.also pressing escape befor it freezes may let you see what is causing the problem while booting up. Maybe come up in safe made,to eliminate lots of taxing stuff. unhook any new stuff you may still have attached. also make sure cd or dvd disk drives are empty.Good luck!
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution » Compaq Laptop's Solution » Acer Laptop's Solution » Dell Laptop's Solution » Toshiba Laptop's Solution » Asus Laptop's Solution
» Gateway Laptop's Solution » IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download » Compaq Driver's Download » Acer Driver's Download » Dell Driver's Download » Toshiba Driver's Download » Asus Driver's Download » Gateway Driver's Download » IBM Driver's Download def-29
