Question about JVC RX-D301S Receiver
Whenever I turn receiver on, it turns off almost immediately
I bought this receiver used alongwith a Bose 5.1 speaker/sub-woofer system. Before buying, tested, worked fine. Got home and hooked it up, would work fine, but there was a loud crackling sound once in a while. Turned out one of the speaker connections was loose, fixed it. It worked fine for a couple of hrs but now, whenever I turn it on, it turns off almost immediately. I even unplugged all speakers and devices, same thing keeps happening. Is a fuse blown? If yes, how could I fix it economically? I would appreciate some guidance/help.
  • rieslok May 30, 2008
    amplifier blew out.i turn the volume high n it messed up it turns off when i try to turn it on.where do i find the parts?
  • dcko Nov 29, 2008
    i have the same problem, when i plug it in, it is in standby mode, but when i try to turn it on, it turns off immediately. I suspect a fuse blew out somewhere. Does anyone know where all the fuse location is? I took mine apart and only found 3 fuses, and they are all intact (wire in fuse not broken). Is there a 4th or 5th fuse somewhere? Thanks.
  • 752 Answers
The amplifier blew out (probably shorted and damaged when wire was loose, and gave out under load). It won't be cheap to repair....
Posted on Sep 13, 2007
Can i hook up my bose model ps38 powered sub to onkyo reciever
Why not. A speaker system should work with anything that produced sound meant for a speaker.
Don't you think?
find the woofer out on the onkyo and connect the bose sub-woofer there.
Seems pretty simple. If you don't think so, go hide in a closet.
NOW!
Aug 19, 2014 | Audio Players & Recorders
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
Subwoofer continuous buzz/signal noise
I just bought mine yesterday and have the same problem... did you find a solution (other than throwing it out the window)?
Nov 18, 2009 | Bose Acoustimass 15 System
How do I connect my Acoustimass® 5 Series III Stereo Speaker System to my Onkyo SR506 av receiver?
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
Oct 28, 2009 | Bose Acoustimass 5 III System
Bose Lifestyle 5 speakers(woofer + 5 double cubes)
I repaired the contol unit per instructions from a post at FixYa.
Sep 11, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Cube speakers w/ no subwoofer
I have the acoustimas systrem and the speakers do need the sb. That's the heart of the system.
I dropped my two front cubes and neither work. If you would be willing to sell yours at a reasonable price I would be willing to buy.
Please contact Bose customer support and I believe they will tell yiou the same thing.
Please let me know.
May 02, 2009 | Bose Acoustimass 5 III System
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
Humming sound
I think it's time for you to upgrade to a new system. If not, try to see if you can get someone that's great with fixing electronics to repair it or return it to the manufacturer for a replacement.
May 15, 2017 | Bose Lifestyle 12 System
JVC RX-D301S Receiver Logo
308 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
