Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Canon powershot S400 will come on, but no functions will work. Won't even cut back off. After about 2 minutes get memory card error, than after another 2 minutes camera will shut down. Help will be appreciated.
    Scholar:
  • 57 Answers
Try inserting other compact flash cards, if the fault occurs with any card the camera can be assumed faulty. Sometimes the pins which connect to the card can become damaged when inserting and require straightening or replacement. You will need to have a service centre repair it for you. Good luck!
Posted on Apr 14, 2009
This is a known "Service Notice" issue announced by Canon.
You'll notice thousands of consumers reporting the exact same problem including myself.
It takes too long to power on the camera, then when it does, it won't take any pictures then after 10 sec or so, "'Memory Card Error" displays. Hitting menu button does not work nor Preview/Playback mode (green light flashes). Camera powers off in 2 min.
Here's THE Solution from Canon - the phone customer rep was super helpful and issued a free UPS return shipping label along with instructions for free repair:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Since this is a known issue, if it indeed is this issue, Canon will repair it regardless of warranty validity. It takes 2 - 2.5 weeks from shipping out your camera to get it back repaired. Hope this resolves your issue as well!
Posted on May 29, 2009
My Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
Sep 12, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Blury lcd screen, but now sometimes the screens black. I also have a memory card error
Canon had manufacturing issues regarding memory errors and also the CCD. They will fix this free of charge. Even if the camera is out of factory warranty. Contact Canon. They were very helpful and fixed the same issues on my S400
Aug 11, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Memory card error
The clock button battery inside the camera has expired. Canon will fix this for free (or if you want, will send you a replacement battery with instructions on changing it out). Read the following recall advisory, then contact Canon at 1-800-OK-CANON:
Jun 20, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Canon S400 problem
The little internal button battery that keeps track of time is going dead. Canon will fix this for free on your model camera regardless of warranty status. Here's the link to the info:
Mar 14, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Memory card error
On the old Powershot S400, this error was caused by a dead internal "clock" button battery. Fixing it required simply replacing the battery. But before you attempt to do that, would first suggest trying a different memory card.
Jan 20, 2008 | Canon PowerShot A540 Digital Camera
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
Memory card error
Canon will fix this for you for free. It's an inherent fault with the S400. It has a little internal button battery that causes the problem as it gets old and run down. Check this website for more info. Look for the bright/bold yellow post describing how to return to Canon.
Good Luck!
Nov 19, 2007 | Canon PowerShot A430 Digital Camera
Memory card error
Solution:
1 set date to 31-12-2030 23h59 and switch camera off.
2 wait two minutes, day will be 01-01-2003 and camera asks you to set the date
3 take away memory card
4 set the date to today
5 insert memory card again
Now your error should be solved.
Sucess, Jonny
Nov 09, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
CF Card Error
Well there is a known problem witht eh CF memory design, i hope this is not your problem but it may be. Take your camera into a well lit area or get a small flash light. Open the memory door and peek down inside the camera and look at the pins inside the camera. Are they all uniform? does any look bent or out of place? there should be 2 uniform rows no pins should be missing or out of place. If they are you have a connection problem. This is one of the issues with this memory format and its why they have changed the design to SD. This is common with people who remove the cards alot and use a reader over time the card and the slot becomes warn and its very easy to bend pins because the card isnt sliding in smooth. If this is your problem (a few bent pins) you may have to take it in for service or try and fix it yourself. Ive read about people using a mechanical pencil. Remove the lead and the pin slips right into the top and you can carefuly move it back. Hope this helps!
Sep 14, 2005 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
175 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
