Question about Kenmore 82836 Gas Dryer
Dryer The "Clean Lint Trap " wont shut off and wont let us run the dryer -
  • Anonymous Mar 14, 2014
    Dryer runs but don't get hot. I clean out trap still want get hot
    Clean out trap and dryer don't get hot
  • 625 Answers
Error codes. are any of these lit? PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Posted on Sep 13, 2007
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Dryer heats but clothes wont dry and have checked lint screens front and back. How much "air flow" should be coming out the back of the dryer?
Do not use this dryer until you fix it. You need to check the pipe or flexible tube that comes out of your dryer (where the hot air comes out). Even though you clean your dryer lint trap some lint gets by. If you can get to it, go outside and find the opening where the dryer air comes out of your house. Then open the little door and look inside but not when the dryer is running. If there is any lint inside clean it out. Then disconnect the air outlet from the back of the dryer and inspect. It should be free of lint. If it is full of lint clean it all out. You can also call a pro to perform the inspection and cleaning. Good luck.
Jan 16, 2014 | Dryers
Electric dryer runs shuts off then starts again on its own
This could be a bunch of different things. #1 detach dryer vent and clean out. Try running dryer with vent not attached for 10 seconds. (Warning, lint and sand will likely come blasting out the back. Reattach and try. #2 Likely is that you have lint buildup inside. Unplug dryer. Remove back cover. Clean air path from exhaust through lint trap. Look inside or remove heater as well. You are likely overheating the dryer and the sensor is shutting it down. #3. Unplug the heating element and then run dryer. Does it shut off still? No Then the sensor on the heating element is bad. Yes then the timer is bad.
Jan 13, 2014 | KitchenAid KEYS750LQ Electric Dryer
Dryer is working but will beep while running and continue to run. I clean lint trap after every load and have checked it.
underneath the lint trap there is a senor, you will need to clean all the lint out inside the dryer and the vent tube:
http://www.applianceaid.com/wpdryer_how-to.html
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My electric dryer runs for awhile then it just shuts off after about 15 minutes of running? Its a neptune.
a couple of things here may be the problem.. First I would check to make sure my lint trap and the dryer exhaust is not full of lint causing the dryer to heat at a higher temp throwing the high limit switch into disconnect due to the amount of heat generated by the coils. This hi limit switch is a safety device to prvent fires. If you find a lot of lint in the dryer vent or the dryer lint trap, once cleaned, see if the machine doesn't operate like you want. Second. The motor bearings or strator may be going out and the motor is going into thermal overload and shutting down to prevent, as you guessed, a fire. I would check the lint trap and dryer exhaust first since it is more than likely the problem and is cheaper to fix. A wet/dry vac should do the trick. Also remove the back of the dryer to clean out the lint paying special attention to the area around the motor vent which can get blocked causing the motor to over heat. Once these vents are cleared the motor may be fine. Make sure to do all of the above with the dryer disconnected from the power source..
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
I smell a burning smell from the dryer. I was running dryer a lot today and tonight I smelt something burning when I opened the door. I noticed my light catcher was full, could this be the problem?
Yes it could have been the lint igniting in the bottom of your dryer in future clean lint trap after every load and take trap door out and vacumn inside trap at least once a month If you ignore the lint trap you could end up with a serious fire so take care of it when you remove screen a certain amnt of the lint falls down into the bottom of dryer and after time a buildup can ignite.. more serious with a gas dryer as the igniter and burner is at the bottom of most gas dryers
Dec 17, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer shuts off on E-1 code..Lint trap has been cleaned as well as vent hose and vent riser to outside.
Check for brisk air flow at outlet of vent hose (hose disconnected). If weak, remove lint screen and retry. If now has brisk flow, clean screen in hot water and detergent.
Aug 01, 2009 | Dryers
Longest 6 minutes ever
I wiped off the two rows of sensors located behind the lint trap inside the drum. Now my dryer shuts off at 0 minutes. The clothes are still a little bit damp so I let the dryer run for 10 more minutes. Try it before replacing the computer board.
Apr 03, 2008 | LG DLE2514 Electric Dryer
Kenmore 82836 Gas Dryer Logo
185 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
