Question about Daewoo FR-147RV
Frigerator not cooling not cooling at all
I have looked an took apart a few things to check it out..compressor runs ..an outside fan in back runs ( evap fan doesnt run) compressor is alittle warm really quite runs nice....the evap is not getting cool or cold i unhook evap fan is out..help me to fix this myself..thankss
  • 8 more comments
  • niceguy123 Sep 12, 2007
    it was givin to me be a weathy family.said it worked i tipped on its side to bring it home in my pick-up truck..plugged it in an never got cold so i started doing checks notice the evap fan not running copressor runs back of frig fan runs when i open the feezer door an took panel off inside i notice fan spin 1/2 turn a few secs then not at all i felt the evap wasnt cool at all ..have any idea's i can check?..its model##amana..srd 2555w side by side R-134A..ITS WAY TO NICE TO JUNK IT .HELP ME FIX IT
    NO NEVER GOT COLD (( NO FROST ))
    HI I LAYED THE REFRIG ON ITS SIDE I LET IT SIT FOR ABOUT 16HRS...IF I DID PLUG THE SYSTEM HOW DO I UNPLUG IT WHAT SHOULD I DO I DID HAVE IT UNPLUG MANY TIMES OVER THE LAST FOR DAYS FOR MOST OF THE DAY AN NITE ..IS THERE ANYTHING I CAN DO ????
    anybody can help how do i know if it clogged or i need gas evap is not cold i can handle what every it takes to fix this i need some input i have a/c gages froen leak detectors..not sure how to tell if needs gas or clogged or what ..nobody can help solve this promblem yet??
  • niceguy123 Sep 13, 2007
    ok im gonna run it all nite again i leak tested it didnt find any leaks..the refrig was tipped over on the side of the fliter so yeah iol can have ran an plugged it ( anyway way to unplug it heat? anything i can do??..# 2 ? is can i buy a tap at the hardware store an but just a oz of freon in just to see if thats it i wanna learn what is wrong i wanna know im having sleepless nite not knowing..an what line can i tap into big line or small line..suction on discharge?? if i get it fixed somehow an get a yr out of it i will be happy..thanksss
    HOW AM I GONNA TAP INTO THIS AN SEE IF IT LOW ON FREON?? OR CAN I TAP INTO IT AN PULL A VACUUM AN RECHARGE IT..HOW MUCH WILL IT TAKE ??AMANA FRIG ..THANKSS
    NOT SURE OF THE AGE OF IT LOOKS AN SEEMS PRETTY NEW..I REALLY LIKE IT I WOULD LOVE TO GIVE IT A TRY.WITH OUT A FILTER JUST TAP INTO IT VACUUM IT AN RECHARGE IT .I HAVE ALOT OF COMMOM SENCE AN I HAVE NOTHING TO LOSE I HAVE R134 FREON VACCUM PUMP. LEAK DETECTORS OIL DYE LIGHT TO SEE IF ANY LEAKS WITH DRY.. ELETRICALI SITE GLASS FOR LIQUID..ALL I CAN BE OUT IS A TAP AN SOME TIME ...CAN YOU TELL ME HOW MUCH FREON IT TAKES OR EVEN IF ITS LOW WHAT ARE THE PRESSURE ON A FRIG RUNNING FOR 30MIN LOW AN HIGH SIDE AN SHOULD I TAP IN LOWSIDE?? OF COURSE I WILL ADD SO SO SLOWLY..THANKSSS ACE HARDWARE AS TAPS I THINK.I DONT WANNA HAVE TO SOLDER ONE IN ..AMANA .MODEL # SRD2555W SIDE BY SIDE.
    ok after running all day still the evap is still room temp not cold at all high side is pretty warm to the touch it has to be plugged passed a leak detecter test after i install a tap an it holds a vacuum then i know no leaks ..if you can help an tell me what i can do to tap in?? an how much freon that unit takes ..thanks guys ..glenn
    is anybody going to tell me how to tap into the frig line???..come on guys these cant be that hard..try working on automive a/c system? ..pulling a engine thats rusted up bolts .someone gonna help me make sure what it is wrong an how to tap into it ...you guys are master tec's or what???
  • niceguy123 Sep 14, 2007
    DUDE ## 1 I DO HAVE A LICENCE TO BY ANY KIND OF FREON I WANT..## 2 DUDE IF YOUR SCOLL UP YOU WILL READ I TOLD YOU WHAT KIND OF FREON IT HAS R-134A.## 3 YES I DO WORK ON A/C SYSTEMS ON AUTOMOTIVE SYSTEMS ##4 I WAS ASKING FOR YOUR HELP SINCE YOUR THE EXPERT OF REFRIGERATORS..##4 THERE IS NO SUCH THING AS A DUMB QUESTION ITS BETTER TO BE SAFE THEN SORRY SO I WAS JUST MAKING SURE SINCE YOUR THE EXPERT..EVERYTHING CAN BE FIXED I DONT GIVE UP I FIGHT TO THE END ON MY PROMBLEMS I KNOW HOW IT IS IN BUSSNESS ,,THE MORE PARTS AN JOBS YOU DO AN REPLACE THE MORE YOUR PAY CHECK IS .I KNOW HOW IT WORKS..SCOLL-UP AN SEE WHAT IM SAYING YOU DIDNT READ IT EVEN TOOK R 134 A ..FROEN .WHATS UP WITH THAT???.DO YOU GIVE UP IF ITS PLUGGED OR DO YOU TRY ANYTHING ?/ WITH NO GARRANTY BUT TRY ..IF YOU GIVE UP ON ADIVE ON A PLUGGED SYSTEM .MAYBE I CAN TEACH YOU SOMETHING NEW... GLENN ( S )..THE TENACIOUS MAN..THANKSS WITH ALL RESPECT
I HAVE A NEW 12 VOLT COMPRESSOR AND EVAPORATOR... I NEED TO KNOW HOW TO RECHARGE THE SYSTEM........
Posted on Dec 05, 2008
Our LG refrigerator wasn't cooling either. With ours it turned out to be that the light wasn't turning off when the door was closed! It seemed unbelievable at first, but the heat from the light bulbs was heating the whole refrigerator section to just about the same temp as the outside room. Here's the key, 'though. If this is the case, the fridge section is warm, but the freezer is cold.
Posted on Nov 13, 2008
  • 291 Answers
Make and model # was there frost on the evap.?
Posted on Sep 12, 2007
  • 3 more comments
  • Mike Johnson
    Mike Johnson Sep 12, 2007
    Did u let it set for aleast 24hrs. after u tipped in on its side??
    If not you have a good change u plugged up the system... with refigerator running...
    u should have a light layer of frost across all the tubes in evaputator... after running for 1/2 hr. or less IF NOT You propley have a plugged system from not letting it stand for at least 24hrs after been on its side...
  • Mike Johnson
    did you lay in down on its side or just tip it some?
  • Mike Johnson
    Mike Johnson Sep 13, 2007
    This is going to be hard to diagnosis, For one u dont know for sure IF it was in good working order when u got it... Then laying it on its side is a good way to plug the system up.
    One way is to leave plugged in over night and see if it buids up a ice ball in one spot just as in enters the evap...
    If experinced enough u can feel the lines in back before filter and after to feel difference in temp to help locate a block... filter and ...capalary tube.. small thin tube coming from filter ... capalary tube and filter are most likey places where could be plugged....
    How old is this refrigerator???
    Good chance there was something wrong with it or why did they get another one?
    Plugged and low or out of refrigerant is very simular semtoms of the problem u have.
    Either way your looking at a major job...
  • Mike Johnson
    For a experience repair man.. Doing these kinds of repairs...I would say u maybe had a chance to save it... IF its plugged, You would have to a at least install a tap valve, change the filter, Vacuum system and recharge.
    If Low on refrigerant...Depending on the leak?
    suction side or pressure, fixing leak would be about the same as above.... If would have to be out of refrigerant or plugged completely not to frost evap at ALL. Which means probley air in system If out of refrigerant.
    I believe you would be better of spending your money on another refrigerator.
    You never said how Old or what Model this frig. is?
  • Mike Johnson
    Well Number 1 Your not licensed to replace or add refrigerant in refrigeration systems.. if you were you woulnt be asking HOW and I could possibley be lible for giving you instruction....
    If you have worked on auto. a/c systems you would know it goes in the same side. There should be info on the model # Tag giveing u the specks u need on how much it holds.
    Do u even Know what type of refrigerant it takes?
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Lennox outside unit fan will not stay running unless i reset the red button
You should replaced the fan motor along with capicator
Jan 10, 2018 | Heating & Cooling
Unit runs but does not cool at all,could it need freon?
Hello
Could be a few things.Usually low freon will cause cooling to stop.
Also a bad compressor will do the same thing.
Check that the condensor unit outside is running,fan turning and you should hear the compressor running.
Check any circut breakers and fuses for being blown or off also.
The outside unit also may need to be cleaned,do this with a water hose and a product called simple green.Spray the simple green on the fins leave on for 5 min then rinse with a hose and water.
Jul 31, 2011 | Heating & Cooling
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
My Rheem Air conditioning unit is not cooling.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There are many things that can cause your air conditioner not to cool…
heatman101
Sep 03, 2010 | Heating & Cooling
My side by side refrigerator and freezer is not keeping cooling temperatures. Freezer had frost in ice dispenser, then began dripping water-had a few ice-sicles and then noticed food defrosting and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
uiot45
Apr 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator freezer not cooling or freezing took off back cover. fan operates. compressor is hot, when pluged in humming noise then drops out.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Crosley CFFH10W Top Freezer Refrigerator
Ge window a/c blows cool air for a few seconds then stops cooling
Its Most Likely Lost Its Freon Or The Compressor Seals Are No Good When The Unit Is On See If You Hear A Whirling Sound Alot Like Your Fridge. Put Your Hand On The Compressor To See If Its Vibrating ( Looks Like A Metal Ball) If It Is Have A Ac Repair Place Check The Freon To See If It Has Run Out Or Is Low. If It Doesn't Feel Like Its Running Have Them Check The Compressor For You. Cooling System Components Should Not Be Serviced By Anyone Who Has Not Been Properly Trained To Deal With Freon.
Sincerely,
Michael Scott
Jul 14, 2009 | Heating & Cooling
Not Cooling
Yes, the compressor might not be running. Possibly a bad run capacitor or maybe burnt wires on the contactor or compressor flags.
Oct 26, 2007 | Weather King 10AJA3601AH Air Conditioner
Refrigerator problem
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
Oct 01, 2007 | Kenmore 93361
Daewoo FR-147RV Logo
761 people viewed this question
Top Daewoo Refrigerators Experts
John Tripp
John Tripp
Jerry Greenberg
Jerry Greenberg
Lawrence Oravetz
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
