Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The light on my garage door opener will not go out. It should go on and off automatically with each opening or closing. I had to unscrew the bulb, because I knew it would burn out anyway with continuous use. Please Help
  • 504 Answers
MANY NEWER DOOR OPENERS ACTIVATE THE LIGHT EACH TIME YOU BREAK THE SAFETY SENSOR BEAM.
THE LIGHT SHOULD STAY ON FOR ABOUT 4.5 MINUTES EACH TIME THE OPENER MOVES OR THE BEAM IS BROKEN.
DOES YOU WALL CONTROL HAVE A LIGHT BUTTON??
IF NOT THE CIRCUIT BOARD STILL HAS THE ABILITY TO WORK WITH ONE THAT DOES. I HAVE SEEN SOME WHERE THE ONLY WAY TO TURN OFF THE LIGHT WAS TO CONNECT A 3 BUTTON WALL STATION & TURN OFF THE LIGHT - THEN RECONNECT THE PUSH BUTTON - OR YOU COULD LEAVE THE 3 BUTTON WALL CONTROL.
YOU MAY ALSO TRY UNPLUGGING THE UNIT FOR ABOUT 5 MIN. THIS RESETS MANY OF THE CIRCUITS ON THE BOARD.
HOPE THIS HELPS
Posted on May 27, 2010
How to open genie 1/2 hp garage opener for light bulb
Set a step ladder under the power head of the garage door opener so you can reach the power cord and the lens cover safely.
Climb the ladder and pull the power cord from the outlet in the ceiling. Press the two lens tabs in to disengage the lens from the power head. The lens tabs are below the opener rail on the upper corners of the lens. Pull the lens cover straight off of the power head.
Unscrew the light bulb from the light socket. Use a new 60 watt bulb to replace the defective bulb. Do not use a short neck bulb. Screw the new bulb into the light socket just as you would a regular lamp socket.
Slide the lens cover back over the front of the power head. Push the lens cover in until the locking tabs engage the top corners of the lens cover.
Plug the Genie garage door opener power cord back into the ceiling electrical outlet.
home light
May 28, 2012 | Sears Craftsman LiftMaster Chamberlain...
My light doesnt come on when i break the sensor....and my learn light blinks none stop
Random blinking of the learn light is normal.
To have your lights come on automatically when you walk into an open garage, you must START with the lights ON. If you don't want that feature and you want to turn it off, you must START with the lights OFF.
To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Feb 17, 2012 | Sears Craftsman LiftMaster Chamberlain...
I am having a problem with my Craftsman 1/2 HP garage door opener 139-53910. My light bulb does not come on when the garage door is opened or closed as it should. I don't have a manual. Is there a...
Make sure the bulb is good. Unplug the opener and remove the bulb. Use a small screwdriver to pry out on the center contact in the light socket. Replace the bulb and plug in the opener.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have 1half h\p chamberlin garage door opener
Unplug the opener and remove the bulbs. Use a small screwdriver to pull out on the center contact in the socket. Make sure you are using standard bulbs.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unplug the unit and remove the bulbs. Using a small screwdriver pull out on the center connection in the socket.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens and closes,light bulbs have been changed, light does not come on when door opens and closes
Unplug the unit and remove the light bulbs. Using a small screwdriver pull out on the center contact in the light bulb socket.
Oct 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Garage Door Opener
THE POWER SURGE PROBABLY FRIED THE TIMER CIRCUIT.
CAN YOU TURN OFF THE LIGHT FROM YOUR WALL CONTROL?
THE ONLY FIX I KNOW IS A WHOLE NEW CIRCUIT BOARD. - NOT CHEAP
HOPE THIS HELPS
Jul 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
143 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
