Question about Canon NP 6035 Copier
Cannon 6035 - no immage on copy pages
Think I may have been to thorough with my cleaning....now my machine spits out copies without any immage....any suggestions as to how I fix this problem. Toner bin is full...
When interior of the machine was opened, I dusted the far right side of the machine and center sections.....
  • 2 more comments
  • marilynn_dil Apr 14, 2009
    Machine is fully fuctional...with the exception that copies do not have any image on them....image trying to be copies doesn't appear on copy sheets.
    Cogz.......Mahalo Nui Loa (Thanks Very Much)...your suggestion was spot on!!!
  • Arthur Hoffmann
    Arthur Hoffmann May 11, 2010
    I am asking: "if you print an image from a computer to the machine, do you get an image on the paper?"
  • Arthur Hoffmann
    Can you PRINT? or COPY? or does it do nothing?
  • Canon Expert
  • 1,326 Answers
Are you getting a totally blank copy or just very light. If I were you I would cheak to see that the developer Lock is in the right place. It seats right under the developping unit. It should be locked to the Left. It will move the developing unit closer to the Drum unit..Good Luck
Posted on Apr 14, 2009
Switching on in morning first few copy come black after going through roller clean option copy become OK cannon ir2010
it is very normal problem in Indian Atmosphere (Reason- Moister on Primary Charging Roller PCR) do not replace anything. try to making copy without Tonner Cartridge.
Feb 25, 2015 | Cannon Office Equipment & Supplies
I have a cannon 6030 copier in my office that is not serviced anymore. I recently changed the toner, following all the directions from the manual. Now It only copies blank pages. It has no other error...
manually jam the paper & see if there is any images on your drum. if no image is there, problem will be in your primary charging. Corona wire may be broken repair it.
if there is image on your drum check if your transfer is ok. replace your transfer corona wire
Apr 14, 2011 | Canon NP 6035 Copier
I NEED TO DOWNLOAD CANON NP 6035 MANUAL
Send your email adress!
But I think that the best way is to buy new one digital age.Its not worthed to waste your time on this machine.
In service manual wont find nothing abaout your problem description.
Check dc controller, power supply, check fixing assy...
Jun 22, 2010 | Canon NP 6035 Copier
Get verrtical lines in center of page when making copies
sound like you need to get a new drum and or clean the mirrors in the scanning assy
Mar 16, 2010 | Canon NP 6035 Copier
Sharp 5316 1 copy good 2 copy good 3, copy blank copy machine on off repeat 3, copy balnak what is the problem
problem on high voltage unite or corona assemble
1.Clean & wash high voltage thoroughly.
2.Replace corona ware,and assemble new corona
upper and lawyer charger.
Jan 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
Duplex doesn't push the paper high enough to finish the second page so it stops the copier ... paper jam.
try cleaning your duplex feed rollers maybe it would help push tru your second page for complition of your duplex copy
Dec 19, 2009 | Canon NP 6035 Copier
I have cannon image runner 4570 that I cleaned
The transfer roller is cleaning use to a vacuum cleaner.The black lines is caused to dirty charge corona or charge roller.Clean the charge unit.
Aug 19, 2009 | Canon Office Equipment & Supplies
Copies are not dark enough
No. This really needs to be done by a tech, it is quite complex, and the optics also should be thoroughly cleaned beforehand as well, in order for it to calibrate properly.
Please rate me :)
Mar 25, 2009 | Canon NP 6035 Copier
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Cannon NP 6035
probably the buttons are not working. you will need to check the control panel (whee the button are at) and check if the micro switches are working properly.
Jul 17, 2008 | Canon NP 6035 Copier
Canon NP 6035 Copier Logo
80 people viewed this question
old marine
old marine
