Question about Kitchen Ranges
"OFF" ON PAD NO LONGER WORKS. I CHANGED THE OVEN CONTROL BOARD TO NO AVAIL. HELP.
    Sergeant:
  • 291 Answers
Either the motor is bad or there is a circuit breaker in the unit which is popping. With the power off, open the unit and try to turn the fan by hand. If it turns hard, the motor is shot. If not, find that breaker and get a new one. They do wear out. You'll probably find it in the housing. They are often small boxes with a wire going in and another going out leading to the fan motor.  -------------------------------- Q: Why doesn't my hood turn on at all? A: These series hood is equipped with a 10-second delay startup and 30-second delay shutoff. If On/Off button is pressed and Speed control is not selected, then the range hood will automatically shut down to conserve energy.
Q: Why doesn't my range hood turn off when I press the off button? A: When On/Off button is pressed once, there will be a 30-second delay. Range hood will run for 30-second before it automatically shutdown. For immediate shutdown, press On/Off button twice.
Posted on Apr 14, 2009
I have a double elec. whirlpool self cleaning oven with accu bake system It will not turn on at all. everything is just off.
This is often due to a control board failure. The board may be NLA (no longer available). It can be rebuilt with a 2 yr warranty. See: http://www.fixyourboard.com/boards/4448876.html
Aug 29, 2015 | Whirlpool GBD307PD Electric Double Oven
The keypad of our samsung microwave oven model no. mw4700w with serial no. 30200123 is no longer working, though it still lights up, it no longer accepts command when pressed. where can i order a spare...
there a many reasons as to why the pad isnt working unless you replace the whole symatic board this is were the fault lays not the touch panal then the fault needs to be found by a tech and repaired
Jul 01, 2011 | Samsung Microwave Ovens
Error code of E1 F2 on a kitchenaid double wall oven. What does that mean?
F2 - E1
Keypad cable unplugged
1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
Feb 15, 2011 | KitchenAid KEBC207 Electric Double Oven
Oven shut off not working
First make sure you have power to the control board. If so, the control board has failed. It is no-longer-available but can be rebuilt by fixyourboard.com.
Aug 01, 2010 | Whirlpool RBS275PD Electric Single Oven
GE model JVM5503 (1980): light and exhaust fan work, but touch pad does not respond to pressing buttons and therefore no functions can be initiated.
That would be a problem with your "touch control" but it is no longer available.
The oven will have to be replaced.
Sounds like it had a good run.
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
What is an f1 alarm code on a kenmore wall oven model 9114012191
problem has been fixed. thank-you for your help.
Nov 10, 2009 | Ovens
F7 error on GE eledtric oven JKP20
This is a shorted touch pad. replace the touch pad or, if the touch pad is incorporated within the control board, replace the entire oven control board.
Jun 25, 2009 | GE JTP20 Electric Single Oven
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
MH1170XSB - Bottom 3 Buttons on Keyboard Pad No Longer Work
We see (and repair) this a lot. The problem is not the keypad, but on the control panel (circuit board), which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 09, 2009 | Whirlpool MH1141XM Microwave Oven
Popcorn
According to the owner's manual (which you can download free from us here),
1. Place the bag of popcorn over an upside-down 9" glass (or paper) plate.
2. Touch POPCORN pad.
It will cook and stop automatically.
If this does not work, you may have a bad humidity sensor or control board, etc. and parts for this model are generally no longer available.
Oct 28, 2008 | Sharp R-9H84B Microwave Oven
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
