about every 5th load of laundry the spin cycle, prior to finishing, will not go into spin. The machine rinses and then just sits there as if it is waiting on a signal to begin spinning. Once the time period for the spin cycle completes the washer then stops.
What should I look for as a cause and possible solution
-   I have the same problem. My machine is about 4 yrs old and it dose everything but go into the spin cycle. I don't believe it is a stuck contact on the timer. If anyone can email me with a fix on this problem please do. I called a repair person and they want 75.00 Bucks just to walk in the door. If I could find a good brake down on this machine I could probably make the repairs myself. Thanks
-   Guest
creda aqua wave 9.5kw electric shower, no hot water, you can here clicking inside the housing as if...
(More)
creda aqua wave 9.5kw electric shower, no hot water, you can here clicking inside the housing as if the motor or solenoid are trying to engage? something was replaced about a year ago to cure the same fault but it has gone again, I regularly clean the head out and make sure no other water device is running to avoid low water pressure etc
My dark clothes are coming out of the washer with lint stuck all over them. Other than running a...
(More)
My dark clothes are coming out of the washer with lint stuck all over them. Other than running a cycle of hot water and bleach, how do I hand clean the washer in places I cannot reach?
I have a Maytag front loader washer and I hear water flowing inside when I rotate the cylinder. Is...
(More)
I have a Maytag front loader washer and I hear water flowing inside when I rotate the cylinder. Is that a problem?
