Question about Balance CN6555 Notebook
My Gateway Notebook will not turn on
I push the power button and the led power light flashes non stop ( I have take the batt out and/or unplug power cable to get it to stop flashing) but nothing happens. No sounds and no display.
  • indigodc Apr 14, 2009
    I'm using the correct power cable. There is nothing attached to the laptop. The power button light is flashing blue. It's flashing approx 10 times every six seconds, and it will keep flashing until I remove the battery. I thought I should tell you, the wireless network led flashes along with the power led at the same interval. The led light that shows the power is on and/or connected is solid blue.
    Hi. Thanks for your help.
  • 11,896 Answers
The battery is completely shot. Even with the power cord, The battery still has to maintain power to work. The light flashing 10 times is a warning that there is not enough power to turn on cpu
Posted on Apr 15, 2009
  • 527 Answers
Sir,
I've read the manual and it says the "battery is heating up, and PC needs to be shut down"
I've shut down the PC for about 12 hours, and turned it back on just now, and it is still flashing.
If it is not worked, try to enter the safe mode. Update the antivirus, windows immediately. If u have knowledge in electronics. Open back cover, reinsert the RAM it will solve the issue.
NOTE: Before making any attempt to remove or replace any part inside the casing, ensure that the power is off.
There's a downloadable manual with step-by-step to overcome computer cannot boot issue. It's handy, printable and it's free. Check this link. U have lot of information relating to your problem check out and go through.....
Thanks
Good Luck
Appreciate to rate as "FIXYA"
Posted on Apr 14, 2009
    Sniper:
  • 58 Answers
Hi
start by removing any new parts (if applies) you may have installed and restart.
if nothing happens, it means that the power supply controller detects an anomaly
check your are using the right power cables, check the voltage and amperes(intensity)
if nothing
can you tell the pattern and the color of the blinking
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    I cannot wake up my HP Pavilion dv3. blue power led flashes on and off and orange connection led too.
    The display driver could have crashed, try holding the power button until the lights go off, and the hard drive powers down (you can hear the spinning stop) then try to power it back on. If that doesn't work, do a hard reset, which would be unplugging it from any AC power, and removing the battery and then reconnecting the battery before powering it on. Should this not work, i would say it's safe to assume the backlight is non functioning and a replacement would have to be ordered.
    May 05, 2011 | HP Pavilion Dv3-1075us Notebook
    Gateway NV5207u will not power on when the power button is pressed. The Power light does not light up when the battery or AC power is plugged in. Can you help?
    Sounds like there is a serious fault in the motherboard. I'm assuming you checked that the AC adaptor is working ok? Check first that there is power to the adaptor and power out of the adaptor by ensuring the green led is on and not flashing, a flashing led indicates power is not making a circuit in the motherboard and therefore a faulty powerboard.
    Mar 27, 2011 | Gateway NV5207u Notebook
    No power. All power cords checked and tight. With
    Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
    If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
    This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
    Jan 06, 2010 | Gateway MP6954 Notebook
    Gateway MA7 (MX6955) Will not boot up, or power on. Battery and AC plugged in battery LED light flashes 4 times and nothing... battery in AC unplugged.. same thing... battery out, AC plugged in.. nothing,...
    hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
    Oct 08, 2009 | Computers & Internet
    Compaq Presario F700 turns off just a second after the start button is pressed... any ideas?
    try holding the esc button when turning on the notebook the power button light should stay on if the hp logo doesnt come on then turn it off and unplug the notebook and unplug then remove the battery plug the notebook and hold down the esc button and start it let the notebook on for about 1/2hour then turn it off and unplug it put the battery back on and plug it press the power button and it should show the hp logo press f10 to go in to bios then change time and date to current and allso change the boot order
    Aug 20, 2009 | HP Compaq Presario F730US Notebook
    Balance CN6555 Notebook Logo
    73 people viewed this question
    Top Balance Computers & Internet Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Jaime Hernandez
    Jerry Greenberg
    Jerry Greenberg
    Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
