Question about Kodak EasyShare Z612 Digital Camera
Cant take a picture although camera turns on
Camera was working fine then for no apparent reason it will turn on (the lens extends out) but the LCD screen is black except for the bottom 1/4" which has a pattern that looks like a picture of moving lights with neon colors and I can not see anything through the eye piece. When I push the button to take a picture nothing happens and I cannot transfer pictures from SD card to computer.
Is this camera now garbage?
  • bkarasiuk Apr 14, 2009
    thanks Art. I tried both of those. putting the card in another camera to transfer worked. But is my camera dead ?? Green light to show power on works, the lens comes out, but cannot take a picture when the button is pushed. I'm thinking it may be time for a new camera.
2 possible solutions. !. try using another SD card. if the one in the camera is full, you cannot take a picture. 2. Try another SD card for transferring, (and taking pictures) and try transfer of this card in another camera or reader, such as the one in photo print places.
Posted on Apr 14, 2009
  • artfrailey Apr 14, 2009
    I don't know about that. But if you really like the camera and it has worked good in the past, it my be you could get it fixed for a small amount of what you paid for it. If it is an inexpensive one, you may be getting rid of a headack. You will have to determine that.
    At any rate, glad I helped you a little, at least you still have a good card.
When i turn my camera on, its a blank screen with
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 03, 2009 | Canon PowerShot A75 Digital Camera
Tip
Fix lens that won't extend fully
If your A360 only extends the lens partway when you turn the camera on in picture mode, there is an easy solution that requires no technical knowledge whatsoever. Mine exhibits this behavior most of the time, and I've experimented it with it and found that these two things help:
1. Hold the power button down the entire time the lens is extending. For whatever reason, this seems to help.
2. If your lens extends only partway (if this is the case the screen and all pictures you take should be blurry), simply hit the macro mode button (the little flower to the left of the zoom) twice. This works because when you go into macro mode, the camera automatically brings the lens to its lowest zoom, which is meant to bring the lens back from a high zoom, but also works in reverse. You may have to repeat this procedure a couple times each time you start the camera (you'll know it's fixed when you no longer hear the motor whine when you press the button).
One last tip: if you've had this problem before and you start up your camera and it seems fine, use trick number 2 anyways, just to double check that the lens is indeed in the correct position. I've made the mistake of assuming, based on the fact that the picture on the screen looked sharp, that the lens was fully extended. When you look at your pictures, you may find that all of them (even those taken with a tripod!) may be blurry.
on Aug 03, 2008 | Fuji FinePix A360 Digital Camera
When I turn the camera on the zoom lens goes in and out three times and then the message says to turn the camera off and then on again. I do this and it does the same thing. I was taking pictures and it...
It is a lens issue, will need to go in for servicing. Possible reasons are knock or grit/sand in lens unit. If you have had it to the beach on a windy day try holding it over a piece of white paper with lens down about a foot away from the paper, give it a few taps on the bottom and see if sand/grit comes out. I fixed these camera's for 4 years and 90 percent of the problems were droppage/ sand related. SORRY.
Sep 25, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Apr 25, 2009 | Casio Exilim EX-Z40 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
LCD frozen
These cameras are very heat sensitive, keep them cool. If your camera is still in warranty, Canon may replace it. Good luck, I really like my 410, it's easy on batteries.
May 17, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
Dec 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Gently tap it on a table or flat surface a few times. Worked for me!
Jul 06, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Zoom shutter wont extend fully
the same thing happened to me. I took my camera apart - just removing the case. I then operated my camera and it became "unstuck". now it works just fine. I put the case back on and all is just as before.
Dec 14, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
109 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
