Can't figure out how to adjust darkness/tone for printer output
My father just purchased an HP laserjet p2015 series PCL 5e. He says that he can't get a nice dark impression with the font he is using. He has an entire manuscript set up using that font and is therefore reluctant to change the font. Is there a way to adjust darkness/tone on this printer? Thank you!
    Scholar:
  • 73 Answers
Below you can see a step by step procedure on how to change the print quality of your work....you need to make test printouts in order for you to see the results....at the end there is a link to the manual for your printer...GOOD LUCK!!!
Print-quality settings affect print resolution and toner usage.
Use the following procedure to change print-quality settings:
1. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
2. On the Paper/Quality tab or the Finishing tab (the Paper Type/Quality tab for some Mac drivers),
select the print quality setting you want to use. The following options are available:
● 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
● 1200 dpi effective output quality: This setting provides 1200 dpi effective output quality
using FastRes 1200.
● 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology
(REt) for improved text.
● EconoMode: Text is printed using less toner. This setting is useful when you are printing
drafts. You can turn on this option independently of other print-quality settings.
Manual
Posted on Apr 14, 2009
Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
Solution
The possible reasons for this error message are as follows:
  • The document is containing both image and text.
  • The font is not supported.
  • Embedded fonts are used.
  • A special plug-in is used.
This issue can be fixed by enabling the following option in Printer Preferences .
To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Rameshkumar . R
cberamesh@gmail.com
Aug 24, 2011 | HP LaserJet P2015 Printer
Unable to print in duplex mode in win 7 with HP LaserJet P2015 Series PCL 6
This may sound like a dumb question but do you have the OPTIONAL duplex unit installed on the printer ?
Apr 09, 2011 | HP LaserJet P2015 Printer
HP LaserJet 2015 printer series - PCL XL ERROR is reported during printing
First Solution :
1. Disconnect the Power Cor from back of Printer ( while printer is has power )
2. Wait for 10 seconds
3. While holding Power Button, Connect the Power cord and release the power button
2nd Solution :
This issue can be fixed by enabling the following option in Printer Preferences . To access Printer Preferences , follow these steps:
  3. Right-click HP Color LaserJet 2015 PCL, and select Printing Preferences .
Jun 18, 2010 | HP LaserJet P2015 Printer
Pcl xl error subsystem: kernel error: illegal tag operator: ox1b position: 6
If you are using Windows 2003 Server and/or Windows XP Client machine and if you hace installed PCL 6 Driver than printer will print pcl xl error while printing.
To fix this problem user need to install PCL 5 Printer driver or Universal printer Drivers from the Link mentioned.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1845552&prodTypeId=18972&prodSeriesId=1845551&swLang=8&taskId=135&swEnvOID=228
Jun 29, 2009 | HP LaserJet P2015 Printer
Install my printer without installation CD
just download :
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=1814092
Thnaks,
Mukund
einfochips
May 15, 2009 | HP LaserJet 1018 Printer
HP LaserJet 2200 Series PCL huge dark smudge
Replace toner cartridge. If problem persist replace fuser unit. P/N # RG5-5559
Apr 28, 2009 | HP LaserJet 2200D Printer
Printer sends error message HP p2015
As mentioned above, install the universal PCL 5 drivers from HP website. This will fix the error.
Feb 23, 2009 | HP LaserJet P2015 Printer
Pcl 5e driver for hp laserjet 1320
Make sure you can view filenames with the trailing dot and 3 letters so you can see the type of file. (Use tools menu, folder options, view, uncheck "hide extensions for known types") Doubleclick on the downloaded file and note where it is unzipping to (c:\lj something or other). Open that folder. Right click on the file ending in .inf and choose "install" in the menu that pops up. If that fails, open the control panel, choose Printers & faxes, rightclick on the HP printer, and choose "properties". Look for the "update driver" button, probably under "advanced". Help it choose that .inf file.
Sep 10, 2007 | HP LaserJet 1320 Printer
1,498 people viewed this question
k24674
