Question about THQ The Lawnmower Man
Please tell me how to remove the blade clutch assembly on a john deere 6 horse power push mower.
  • Yannick Verhoog May 11, 2010
    For guides and walkthroughs you will have to look elsewhere on the internet.
    Forums like this are for people with real problems...
    Sergeant:
  • 239 Answers
In your system go to control panel and select add or remove programs in that the list of program shows the blade clutch box click remove to click the program will removed easily.
Posted on Apr 17, 2009
John Deere LX176 fuse blows when pull up button to engage blade.
look where the wires go threw the frame to the clutch and unplug the connector and try a new fuse if it still blows remove the clutch and inspect the wires they do rub on metal and short of the power
May 28, 2012 | John Deere Garden
John deere 3800 forage chopper tractor's horse power requirement
I run a lot of choppers. More hp the better. We had 6-cyl. diesel 90 to 120 is best.
Apr 01, 2012 | Garden
Hello Sir, I have a john deere 25 horse 48 inch cut,the first thing that happen was the orange button you push to back up with blades engaged quit working and then the blades wouldnt come back on after...
sounds like the switch is bad, you will need to check it, as it may be just a loose connection, you can jump it out to test it out, or just straight wire it. Good luck Tim
May 22, 2011 | John Deere Garden
I have john deer sabre 18 horse i have a snow blade but cant get on right
My name is Dane and I'll try to help you with your problem. I have given you the basic instructions here for mounting most john deere snow blades.
Here is a link to the parts diagram for the blade too.
http://www.searspartsdirect.com/partsdirect/part-model/Sabre-john-deere-Parts/Riding-mower-tractor-Parts/Model-15538G/1828/1509200/10060752/00034
You need to remove the mower deck from the machine, and you may have to remove the front bumper as well.
First, install the mounting brackets on the tractor. Align the holes in each mounting bracket with the holes in the tractor frame. Install using the kit that comes with the mounting bracket. Don't tighten this yet.
Next you should install the pivot support. Insert the pins on the right and left hitch plates into the notches on the mounting brackets. Install the pins and tighten the screws on those mounting brackets now.
Next you should Install the blade. Align the holes in the pivot support with the second holes from the end of the push channel assembly. Insert the channel pin and washer and secure with the spring locking pin.
Install the lift handle. Slide the lift handle rod into the end hole in the push channel assembly. Insert the lift link pin in the pivot support bracket into the lift handle rod. Add the washers and locking pin.
Now, Iistall the blade pivot rod. Either end of the blade pivot rod goes through the blade pivot shaft. The other end goes through the lift handle tube. Secure both ends with locking pins.
Lubricate the lift handle rods and pivot points.
Install the rear tire chains and wheel weights.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | John Deere Garden
I have a John Deere L-130 and the electric PTO appears to be engaged even when the switch is turned off and the wiring to the PTO is disconnected. I can start the engine (with the wiring disconnected) and...
Good diagnostic work, uncleparroth! By removing power to the PTO, you've proven that the PTO clutch has stuck/frozen mechanically. If you are mechanically inclined, you can remove the PTO clutch assembly and disassemble it. You could luck out, find something as simple as a broken spring and save a lot of money. Nothing to lose but your time. On the other hand it might not be repairable and you'll have to 'spring' (sorry for the pun) for a new PTO clutch which will cost about $200. Good luck!
Aug 08, 2010 | John Deere Garden
How do we service the blade / brake clutch assembly on John Deere 14SB lawn mower .
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Nov 14, 2009 | Garden
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Clutch adjustment on a John Deere JX 85 push mower
my jx85 when cutting grass with my jx85 the power to the blade dies if i lift it up the power will come back put it back into grass it dies again any ideas please
Jun 21, 2009 | Garden
Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
May 25, 2009 | John Deere Garden
THQ The Lawnmower Man Logo
83 people viewed this question
Top THQ Video Game Consoles & Games Experts
Jimmer_9
Level 1 Expert
James Wishart
William Wurtinger
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
