Question about D-Link RangeBooster G DPR-1260 (DPR1260) Print Server
HP LP1020 I just bought a DRP-1260. When connecting my 2 printers - a somewhat older HP DJ5150 - a brand new HP LJ 1020 Both printers got detected correct by the print server. But the DJ got status ready while the LJ 1020 got status Offline. Using the installation exe which you download from the configuration page of the print server, I was able to install both printers. In windows they both appear online. On the status page of the print server, the DJ appears ready while the LJ 1020 appears Offline. When trying to print, the DJ works fine, while the LJ1020 doesn't do anything. Switching my LJ on and off doesn't seem to work. To the print server it is offline. Anyone got this working with a LJ 1020? I mailed to get support from Dlink but as for now they only told me that it is not on their compatibility list. Even though i found a list of compatible printers on the website of dlink taiwan on which the LJ1020 is said to be compatible. Thx
  • Anonymous Dec 24, 2007
    Having same issue with a HP Laserjet 1020. I haven't found a fix either. It's like you said, if you connect the printer to the PC via USB first and then immediately connect it to the print server it works. ...that is until the printer or print server gets power cycled.
    New Friend:
Ok, y solved linking the printer with the application provided with the dpr, PS-link, its added a new port and printer and works fine since. hope helpfull
Posted on Jun 10, 2011
It seems that I found an imperfect solution. When you intall the printer on your PC and print a testpage, the firmware is sent from PC to printer and is stored in the printers internal memory. When you unplug your printer from your pc and plug it in on your printserver it should work fine as the firmware has been loaded alraedy. You can't switch of the printer nor the printserver or the firmware needs to be uploaded again via your printer. There is no way at the moment to load the firmware upon booting of the printer by the print server. Hopefully this issue will get resolved in the near future.
Posted on Oct 03, 2007
SOURCE:
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
Jan 31, 2013 | D-Link Dpr-1020
Seiko lp1020 led head
Sir..,Not help for local dealears.,
So. pls ur help sir.,
SEIKO LP-1020 Model Machines
MEP Board (PCP) AFXY U00077354803 (Board arjent)
Account No pls send sr.,
waht price sr.,
Pls help sr.,
Aug 08, 2012 | Seiko Teriostar Lp1020 Printer / Copier /...
Tray setting of HP laserjet 1020 printer
This can be done i several ways.
If your printer is a network-model, you can enter the printers IP-address into your favorite web-browser and set the settings as you want from the web-interface.If your printer is a USB-model, you have to download the software for the LaserJet 1020. This package contains a software called Toolbox, and that's the software you need to set proper settings in your tray. Follow the link for downloading the Toolbox-package.
http://ftp.hp.com/pub/softlib/software8/COL14041/lj-39322-2/hp_LJ_1020-1022_Full_Solution.exe
Apr 20, 2012 | HP LaserJet 1020 Printer
My hp laserjet 1020 dose not initialized
replace fuser unit or fuser heater hp lj 1020
Mar 29, 2012 | HP LaserJet 1020 Printer
Problem with my HP LJ 1020 is when i print through network
LJ1020 is not a network printer. I think this printer connected to a local computer which may called as print server. and the printer connected to all other computers through this computer. if it so, Pl. let me know that whether the print finish its process when it was given from the Print server. if not, Pl uninstall the driver from the print server and reinstall.
Aug 26, 2009 | HP LaserJet 1020 Printer
Help repair
1- there may be a Shutter on the inside top that is not being activated when you put in the cartridge, check to see if there is some kind of lever,.
2-make a print and stop it before it goes out take out the cartidge and look if there is toner on hte drum. this eliminates the drum
3- there is a gear that drives the drum, check
Aug 07, 2008 | HP LaserJet 1020 Printer
HP LJ 1020 Output Page Jams @ Fuser input
either your fuser is bad or output rollers, I put my money on the fuser
Mar 26, 2008 | Office Equipment & Supplies
Can Not Print to HP LJ 1020
hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
D-Link RangeBooster G  DPR-1260 (DPR1260) Print Server Logo
1,478 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
