Canon mx310 wase ink full. Any ideas how to reset
  • 4,338 Answers
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 13, 2009
  • 2 more comments
  • cherry_tolmi Oct 28, 2010
    Thank you so much this helped me sort it out no need to go to the service center
  • pochoa Nov 10, 2010
    Thanks Joe the printer is working perfect now. No need to take it to service or buying a new one. Your a brain. Thanks a bunch.
  • norbertroede Jun 19, 2011
    Hallo,
    habe gerade beim Drucker Pixma mx310 nach vorstehender Anleitung den vollen Tintenauffangbehälter zurückgesetzt. Es erscheint auf dem automatisch erfolgtem Ausdruck der Hinweis "D=000.0 Ps=000.1!" Hat allerdings erst funktioniert nachdem ich ca 1 Minute auf dem "Service-Modus" nichts gemacht habe. Danach aus - und nach einer kurzen Zeit (einige Sekunden) wieder den Drucker eingeschaltet habe. Es erfolgte danach nochmals ein intensiver Reinigungsvorgang und jetzt klappt alles wieder.
    Besten Dank für den Tipp!
  • preb Apr 14, 2012
    After having read and tried many other suggestions that didn't work, I didn't expect much from this advise either - but IT WORKED for my MX700 as well (same happened to me as for norbertroede).
    Thanks a lot. You are great!
Joe's solution worked perfectly for me on the MX310.
Thanks Joe.
Posted on Jan 04, 2010
Didn\'t work. now im just stuck with the alarm light on and every time i turn it on and off it wont let me do anything else it says "check ink" when I have replaced both.
Posted on Sep 16, 2013
How to reset the full ink absorber
You do not want to reset the waste ink absorber. The machine monitors the waste absorbers, and they are full. If you continue to use it, it will leak waste ink. Take it in for absorber replacement, or replace the unit.
May 01, 2011 | Canon PIXMA MX310 All-In-One Printer
Error code 5B00 Canon MX 310
you need to reset the waste ink absorber,your absorber is full
Feb 24, 2011 | Canon PIXMA MX310 All-In-One Printer
I have Canon multifunction MX310 I was using
press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.Canon do not like you to use refills and generic carts so the function for detecting the remaining ink level will be disabled
Jun 19, 2010 | Canon PIXMA MX310 All-In-One Printer
"set ink cartridge" message on Cannon pixma MX310
pull them both back out. Put them back in until they click. When you put them in push them on an angle
May 07, 2009 | Canon PIXMA MX310 All-In-One Printer
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
MX310 error code U163
Can you tell me, have you replaced the empty tank with a full one? And, have you manually reset the ink level function by pressing Stop/Reset for a full 6 seconds (one second longer than described in your manual?)
If you have, and you still see the ink cartridge light flashing, does it flash every second or every three seconds?
The contacts for the ink cartridge are easy to contaminate by accident. Sometimes wiping the contacts off with alcohol will clean them enough for the ink level to be recognized.
Now, and yes, this is a common problem. Press and Hold the Stop/Reset button for 6 full seconds again after cleaning the contacts and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again. Okay?
How long has it been since you purchased this printer?
Regards,
Worldvet
Oct 15, 2008 | Canon PIXMA MX310 All-In-One Printer
Reset Waste Ink Canon MX318
Because It is full. And replace or you can clean it. Either way you must any of this two things.
Good luck.
Sep 16, 2008 | Canon MX310 Office All-In-One Printer
7,777 people viewed this question
k24674
jasbo
jasbo
