Question about Gateway 1532121 Monitor
Gateway 22" Monitor
I own a Macintosh computer and the EZTUNE disc has only a software program for a PC. Is there any software available on an EZTUNE disc for a Macintosh.
  • charcoal Sep 14, 2007
    I want to know if there is an EZTUNE disc with the mac program on it to load in my computer. If I have any problems I don't want to have to be taking it to the store every time I get a MENU LOCKED message. Without a mac program I can't remedy it. The EZTUNE only has software for a PC, which doesn't help me at all.
    Scholar:
  • 113 Answers
Hi there! well, EZTUNE should be a mac version, so it could play to your macintosh computer also. you can download the mac version at torrent sites, just be patient searching it.
Posted on Dec 15, 2008
SOURCE:
How to restore eztune
Funny you should ask. I was just reading my Gateway monitor manual this afternoon and it says you can download EzTune software from http://oem.portrait.com/dtune/gwy/enu/upgrade.html. Be sure to to download the right software for your monitor. Apparently there are different versions for different monitors
Dec 17, 2012 | Gateway 19" Widescreen Flat Panel TFT LCD...
Tip
Gateway LCD monitor EZTUNE theft protection problem
You need to install EZTUNE but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN. https://pinreg.portrait.com/change_p...=dtune&OEM=gwy
Forgot your PIN? https://pinreg.portrait.com/remind_p...=dtune&OEM=gwy
GatewayShield™ Security Available
Protect your hardware using the EzTune™ Anti-Theft Software and reinforced lock slots. The slots, paired with a cable lock, physically anchor your display to a secure fixture. The software keeps the monitor secure using a unique PIN code. In the event the display is removed from the PC without the code, its full functionality is disabled.
on Apr 14, 2010 | Computers & Internet
Cannot uninstall eztune My new gateway monitor had eztune that didn't work so I downloaded another and it says it is incompatible and That I have an older version running and need to uninstall but I...
Please follow the link below to download Microsoft Uninstaller Cleanup Tool.
Save this program to your Desktop, and then install it. The file should be named "msicuu.exe". Once it is installed; follow these directions.
1. Open C:\Program Files\Windows Installer Clean Up\ or if you are running a 64-bit Windows Operating System: C:\Program Files(x86)\Windows Installer Clean Up
2. Here you will find the msicuu.exe program. Run this program by right-clicking on it and choosing "Run as Administrator".
3. You should see the Windows Installer Clean Up window open.
4. Find the entry, (All Users) EZTune Monitor and left-click on it once to highlight it.
5. Locate the "Remove" button below and left-click on it.
6. After a breif moment, the program should be removed.
7. Close out of Windows Installer Clean Up; and run your downloaded EZTune Monitor program again. It should install now.
Aug 28, 2011 | Gateway Computers & Internet
Monitor message says "Theft Disable
The theft deterrence system can be disabled temporarily by unplugging the monitor's power cord. Then it will start the counter again. (The default is 60 minutes and is set in the EzTune software.) The software locks the monitor to one computer (the one running the EzTune software). To disable the theft deterrent message, enter EzTune and click on the Extras tab. Then select the Theft Deterrence section and enter the PIN. The PIN can be saved online and then you can request it if forgotten: https://pinreg.portrait.com/index.php?OEM=gwy&PRODUCT=dtune&ULANG=enu .
The EzTune software is available here: http://oem.portrait.com/dtune/gwy/enu/upgrade.html .
The user's guide and other documentation is available here: http://support.gateway.com/s/MONITOR/7005574R/7005574Rnv.shtml .
I hope this helps.
Mar 15, 2011 | Gateway FPD1975W 19" LCD Monitor
My monitor doesn't let me type in the password. If i click to change the password it asks me for a disk on which the password is supposedly stored. I don't have this disk, I don't racall the monitor came...
This monitor includes EzTune™ which is part of GatewayShield's hardware protection solution.
This theft deterrent software lets you use a unique PIN code to secure your monitor
to your PC. If your monitor is removed from your PC, your monitor will not
function. To get started, install the EzTune software from the CD, go to the
Plug-ins section and enter your personal identification number. If you decide
to move your monitor to another PC, make sure that you install EzTune on the
second PC and enter your PIN or disable EzTune within GatewayShield on your
original PC before you disconnect your monitor from your PC
Dec 14, 2010 | Gateway FPD2275W LCD Monitor
I have a Gateway FPD2185W monitor with a NVIDIA Gforce 9800 GT. Software was delivered with this monitor to suppor the Pivit features. I have had a few problems with IE since that time, but nothing I could...
The Pivot software is part of the EzTune application. When you installed EzTune, it automatically configured itself with your currently installed drivers. When you update your video drivers, Pivot must reconfigure itself. This is normal operation.
EzTune version 1.4 and later is compatible with Windows Vista.
The latest version of EzTune can be downloaded from the following Web site.
Hope that helps...
Apr 11, 2010 | Gateway FPD2275W LCD Monitor
Gateway Monitor 22" flicks on at start up, then shuts down
Coulld be a MBR problem.Try to debug and check in safe mode.Reinstall Operating System.
Jul 06, 2009 | Gateway GT5468 Desktop PC
Lock out of my computer through eztune-
Call Gateway @1-800-gateway. They will tell you to unplug the monitor, plug it back in while holding the power button. A screen will apear giving you a code number. The gateway rep. asks for the code number and then gives you a code number to unlock your screen.
Oct 25, 2008 | Gateway FPD1975 19" LCD Monitor
EzTune problem with lost PIN number to disable Theft Deterence
Whatever you do - DON'T CONTACT GATEWAY. I am in the UK, and the Gateway support number is only available 9 - 5 (funny 'cos I'm at work then and can't access my PC), so I filled in the technical support form - waited 2 days for a reply only to be told they don't support third party software.
I had an online chat with US Gateway support - only to be told the same thing - alternatively, pay them silly amounts of money and phone the US and they will fix the problem.
The solution is to visit Portrait Displays (software developers) website and complete an online form with your problem. (This form prompts as to whether you have already contacted Gateway - so maybe they are monitoring the adequacy of Gateway support. The support from Portrait has been brilliant.
Unplug the cable from your monitor and then hold the power button while you plug the cable back in. When the monitor is fully restored,
release the power button and an anti-theft box will appear, prompting you to press the menu button at the side of your monitor. Press the menu button and you will be given a 3-digit code. Portrait need this code to give you an unlock code. Once you have the unlock code you can remove the anti-theft option.
Feb 29, 2008 | Gateway FPD1975 19" LCD Monitor
Open Questions:
See all Gateway 1532121 Monitor Questions
Computers & Internet Logo
688 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
