Question about Canon MultiPASS F60 All-In-One InkJet Printer
Black marks along the edge of paper
I have gone through all the maintenance steps and I'm still getting black marks along the right side of the paper.
  • Binesh Ellupurayil Balachandran
    the ink has splilled out of the catridge check
    check the starting of the black mark
  • 51 Answers
There is probably ink on the rollers. get some paper and just keep feeding it till the black marks stop. and RECYCLE the paper that you fed. DO NOT throw it out
Posted on Apr 13, 2009
Loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Mar 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HP P3005 - skid marks along paper's edge
Print 3 pages. Use the manual feed tray. As they print, open the cover, remove the toner and look down at the paper in the printer. Do you see marks along the edge? If no...replace the fuser. If yes...it could be the transfer roller.
Jan 07, 2010 | HP P3005d Monochrome LaserJet Printer
Doesn't recognize paper when loaded
When loading the paper, the edge sensors can be a bit tricky.
Pull the paper through the main guide with the locking plate released. Guide the paper edge it's right along the blue (not over it, just along the left edge of the guide markings on the body of the unit). Pull the paper through and then guide it back so that the lead edge just barely shows up, below the small, black rollers in the main print area. Now lock it down and reboot the system.
Once the print head alignment has finished the unit will pull the paper through and then move it forward and back until it is properly aligned, then cut off any excess it detects.
You should now be able to print. Note: Please do not re-adjust the paper edge after this process is complete.
Aug 09, 2009 | HP DesignJet 1050c plus InkJet Printer
Black roller marks on right side of paper
Sounds like you have a bad fuser assembly if the drum unit didn't solve the probelm.
Mar 16, 2009 | Brother HL-5240 Laser Printer
Each time I print on plain paper the paper feeds into the machine and when it hits pinch rollers after the print head, the top right hand corner is turned over. Two pages later and the third page is so...
Follow these steps to reload paper:
  1. Flip the feeder guard forward.
  2. Remove the paper and make sure it's not curled or wrinkled.
  3. Fan the stack of paper to make sure the sheets are separated.
  4. Reload the paper against the right edge of the sheet feeder andslide the left edge guide against the other side, but not too tightly.
  5. Don't load paper above the arrow mark on the left edge guide.
  6. Make sure the printable side of the paper is facing up.
  7. Flip the feeder guard back.
  8. Once you have completed the steps above, press the cp_button_6.gif Start button.
Mar 07, 2009 | Office Equipment & Supplies
Changing paper on HP Designjet 5500 Plotter
Step 1. Install a roll of paper on the spool, and install the spool on the printer. The fixed end of the spool should be on your right side as you face the printer. The paper should come off the top of the roll.
step 2. open the window and support it with the built in support. Lift the blue handle, located just to the right and above the spool adjacent to the black roller.
Step 3 Pull out about a yard of paper and feed it in front of the black roller and in back into the printer. You really don't need to be precise, the path will accept the paper. Keep pushing the paper until it comes up the the top, then pull the paper from the top.
Step 4 If the edge of the paper is cut square just line it up with the front edge of the printer and on the right there is a blue edge guide mark. If the paper has not been cut square then pull it out far enough that it reaches the spool and line the left and right edges up with the roll and also the blue line.
step 5 Lower the window and the handle. The printer will attempt to install the paper. Respond to the questions that appear on the screen and you should be good to go.
I can walk you through it by phone if you need more help.
Jan 28, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
Black ink mark
try this......run a card with heavy matte paper using 'regular settings'.....see if the extra black is gone then
Oct 04, 2008 | Epson Printer
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
Canon MultiPASS F60 All-In-One InkJet Printer Logo
964 people viewed this question
old marine
old marine
