The Main Memory Backup battery in my Sharp Wizard OZ-7620 is depleted. I have replaced the 2 replaceable batteries but I don't know how to restore the system.
  • Mikeballard2 Apr 14, 2009
    This unit is handhel, early version, PDA, It has a main battery and 2 replaceable CR2032 batteries.
    Problem Solver:
  • 4 Answers
First and foremost, I have to how you removed the battery and how you replaced it? cos there are methods of doing this.
well in case of another time, you have to disconnect all cables on the board including the Cd, battery and others, then you can go ahead and do what you said you've done.
Posted on Apr 14, 2009
Reset password on my sharp oz-779
You need to Contact the manufacturer.Go to authorized service centre of sharp .They will provide you the code to bypass the lock.
Thank you
Nov 07, 2010 | Sharp Wizard OZ-770
TI-83 Plus ram cleared message when turned on
It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
  1. Check that main batteries are good and inserted in calculator.
  2. Turn calculator OFF.
  3. Replace the backup battery.
  4. Turn calculator ON.
  5. Press the [CLEAR] key to erase the "Ram Cleared" message.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
Won t turn on- NOT the 4 AAA batteries. Could the backup battery affect the main power??
To answer the question you asked. No the backup battery does not affect the main batteries. It is there to keep the memory electrically refreshed when calculator is turned off. You will know that the backup is depleted or almost depleted if the screen displays RAM CLEARED, everytime you turn the calculator ON.
Now to the calculator not turning ON. IF THERE ARE NO HARWARE PROBLEMs with your calculator (of this I cannot judge for I am no prophet) , it may be that the screen is too light and you cannot see what it displays. If that is the case, you can darken it as follows.
1. Press [2nd] key and release it.
2. Press [ArrowUp] key and release it.
3. Repeat Steps 1 and 2 in sequence, until screen darkins enough. You may have to repeat the sequence several times.
Hope it helps.
Oct 11, 2009 | Texas Instruments TI-83 Plus Calculator
Sharp wizard oz-290HII --fading screens
Friend, try to replace the battery. If it doesn't work try to press firmly the LCD connection interface underneath the screen because such unit has lossen connection.use T6 screwdriver to open the unit then slowly firmly press the LCD connector on the interface. Such thing will solve the problem. good luck
Jun 16, 2009 | Sharp Wizard OZ-290
Replace battery in Sharp OZ-8000 pda.
unscrew 3 little screws at the bottom cover using jewelry phillip driver-remove the cover- you will see further instructions inside the cover. This model requires 5 batteries CR2032 (4 for main memory-1 for backup memory)-Hope it helps.
Apr 11, 2009 | Sharp Wizard OZ-800
How to do with Sharp ZR-3500
On the back of the unit, there is a battery selector switch. Move the selector to the 'replace batteries' position. Now you can open the main battery compartment. Adjacent to the main compartment is a smaller hatch secured by a small hex-head screw. Loosen and remove the screw to remove the hatch cover. Then you can remove and replace the old 2032 battery with a new one. Reverse the procedure to secure the hatch, ensure you have fresh batteries in the main battery compartment, replace the main hatch, select 'normal operation' and you should be good to go.
Jan 08, 2009 | Sharp Zaurus ZR-3500X
Sharp OZ-730 (deceased
When you held the start button down and pressed the reset, did you get a message appear ? as per the manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000002412.pdf
Oct 11, 2017 | Sharp Wizard OZ-730
Sharp OZ-630
Do an ALL RESET. The only way i know of to do it is to hold the ON and Reset at the same time. Then select yes at the promt. Then wait 2 mins and take out batteries. Reinsert and turn on. it will re-format. This is the only way i know of how to ressurect it, but it deletes ALL you data.
Thanks
Aug 18, 2008 | Sharp Wizard OZ-630
Loss of data when battery goes dead?
-are all pda's this way? All PocketPCs are this way. I don't own a P**m so I can't speak to them. -When the main battery depletes to the point where the unit shuts off how long do you have before data is lost? Until the backup battery dies. -Is the backup battery just used when changing main batteries or does it take over when the main battery goes dead? If so how long do you have before it is dead? I've never had it happen, so I cannot say how long, but if you continue to try to use the PDA on the backup battery it won't be long (minutes) if it even lets you do that. The backup is there to bridge over battery changes and to act as a safety net if you run the main batteries totally flat. -does the backup battery recharge or does it have to be replaced? Replace. -with a fully charged unit how long can it be left off before data is lost? Depends on the machine. Most of us leave the thing in the charger overnight every night, so this issue doesn't come up. You could try an experiment for 1, 2, 3 days, looking each day at the battery remaining and work up an estimate. I would expect maybe a week or more. Remember, even "off" the machine is still drawing power to maintain the RAM memory.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
335 people viewed this question
David Payne
David Payne
