posted by peteronline on Sep 12, 2007
my incoming faxing are terribly dirty. How can i clean the toner or what needs to be cleaned??
Best Solution
posted on Sep 23, 2007
open fax cover and you should see a strip of glass,use a little rubbing alcohol on a q-tip,wipe gently.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 09, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The easiest way to find out if YOUR fax is the problem is by making a COPY of an original. If your original is clean and the copy looks dirty, then you need service. If your copy is clean, then the sender needs his/her unit serviced. Whatever the image looks like when you make a copy, is exactly what your sending and the recieving party is going to get. If your original is clean and you find lines on the copied page, THEN your **** glass (scanner glass) needs to be cleaned. Open the feed section where you insert the originals and look for a long, skinny length of glass. It most likely has dried white-out or glue on it. Clean that gunk off and presto. Tell everyone your new name is Sam Breakstone (Im A GENIUS) Im a Tech and I use steel wool when I find this common problem. it wont scratch the glass so dont be a coward. And keep this secret to yourself or ill be outta business. Consider this My annual Tech tip freebie!
This Problem Also Relates To:
HP 1020 Plain Paper Thermal transfer Fax
HP 1010 Plain Paper Thermal Fax
HP 910 Plain Paper Inkjet Fax
HP HEWQ8096A Color Inkjet Fax Machine,33.6Kbps Modem,16-3/4"x8"x7"
Panasonic DX-2000 Fax
Panasonic Panafax UF-333 Plain Paper Inkjet Fax
Panasonic Panafax UF-890 Plain Paper Laser Fax
Can you Help with these Fax Machines problems?
Repair Service
Find Fax Machine Repairman Near You:
