Question about B&C Allis Chalmers Tractor B,c,ca Front Wheel Cone Outer
Allis Chalmers tractor wont start
I have a 1947 model C Allis Chalmers tractor. It has sprark and will run while being towed but will not stay running.
bargainbin2
  • 123 Answers
SOURCE: Snapped Brake belt on an Allis-Chalmers T-811 lawn tractor
What is the trouble you have said nothing.
Posted on Aug 26, 2009
wireguy212
  • 1627 Answers
SOURCE: When setting points on a CA Allis Chalmers
Set the gap on the high spot on the lob,it should be set at around 50000 or twice the plug gap,this is just a rule of thumb,but changing the timing by turning the distributer will get the engine to max performance after this has been done.
Posted on Apr 07, 2010
roadtech7
  • 293 Answers
SOURCE: I have a allis chalmers lawn tractor wont start
Check the volatage at the battery, then check the voltage at both sides of the solinoid. You should have the same voltage at one side, and none at the other ( the one going to the starter/generator). The other problem could be that you have lost your ground. Try cleaning the battery terminals, and with the meter set to volts DC, touch the red to the positive terminal and the black to a known ground (engine block, tractor frame, exaust manifold) and your meter should read the same as it did across both terminals. If it is less, you need to clean the ground at both ends. If you hear a "Click" when you turn the key to the crank position, you know that the solinoid is good. Have you tried to jump the tractor with your truck or car?
Posted on Nov 07, 2010
  • 135 Answers
SOURCE: The hydraulic pump does not shut off and the lift
Sounds like you have a hydraulic flow valve problem. Check the lift arms when the pump is running to see if you have any hydraulic fluid leaking there.
Posted on Nov 18, 2010
SOURCE: I have an Allis -Chalmers 416 tractor with mower
There are 2 holes at the front on the frame you need to put a pin and cotter pin through each side to hold the front of the mower. Then there will be a hangin piece of straight metal about 2-3 inches long with a hole in it that you need to hook up the chain to also with a pin with a hole in it and a cotter pin. This will allow you to raise and lower the deck with the electric lift. If you need pics let me know i'd be happy to help.That's all there is to it besides putting the belt on.
Posted on May 29, 2011
1936 Model M Allis Chalmers crawler. Where can I get a free manual download?
Hi Jason:
I'd try to locate the nearest antique farm equipment club and see if I could connect with someone who had a manual that I could either buy or copy.
Here's a link that will perhaps assist in getting you started.
https://www.google.ca/#q=1936+Model+M+Allis+Chalmers+crawler+manual+
Cheers.
Dec 26, 2015 | Garden
410 allis chalmers
Specs Link:
Allis Chalmers 410
Parts Link:
Simplicity Allis Chalmers Mower Parts
Had a friend who took off his Yamaha branding on a Motorcycle and replace with AC brands - AC rocks.
Mar 03, 2015 | Garden
How to set engine timing on allis chalmers model 2900 engine?
SEARCH ALLIS CHALMERS 2900 ENGINE SPECS, FOR THERE ARE QUITE A FEW SITES.
Sep 05, 2014 | Garden
My Allis Chalmers 6080 PTO will not shut off with the lever. Even though I pull the lever to stop PTO, it stays engaged. Any answer to this issue?
The lever is maybe not engageing the electrical switch so if it worked good in the past something has worn or come loose.Find the point where the lever engages the switch and there are usually 2 wires running to the pto.Also one or more wires might be off the pto.Go from one thing the lever does to the next step and it might be a bad switch if the lever is working the switch and it still does not turn off.Hope this helps
Nov 05, 2012 | RTO Allis Chalmers Tractor Pto Shaft...
Allis 190 wont start
recheck the gap on the points they could have been a little loose then try another condenser
May 15, 2012 | RTO Allis Chalmers Tractor 180, 185, 190,...
The hydraulic pump does not shut off and the lift arms will not go down on my d19 allis chalmers tractor.
Nov 18, 2010 | Dmm Allis Chalmers Tractor D19,d21,210,220...
Allis chalmers AC 5040 is leaking water/fluid
looking for in the oil cooler inside the radiator maybe is broken.
Jul 11, 2009 | B&C Allis Chalmers Tractor B,c,ca Flywheel...
Allis chalmers 912 hydro belt diagram
I also have the same tractor but i have what your looking for so my email address is rickralston73@yahoo.com
Jun 27, 2009 | RTO Allis Chalmers Tractor 8010, 8030,...
B&C Allis Chalmers Tractor B,c,ca Front Wheel Cone Outer Logo
357 people viewed this question
Top B&C Garden Experts
Dennis Key
Dennis Key
john h
Are you a B&C Garden Expert? Answer questions, earn points and help others
