Question about Kenmore Elite Oasis 27052 Top Load Washer
Keep getting L1 error code on Washer when I start a load. If I press stop and then start again the error code appears again. I have to do this 3 to 4 times before it will finally work.
SOURCE: Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Posted on Oct 15, 2007
geemarie
  • 876 Answers
SOURCE: Kenmore Elite H3 Error Code F71
The computer needs to be reset most likely. You might try turning it off, uplugging the washer, leaving it off for a bit and starting over. They are touchy little machines, I've found, not just your brand either. Mine comes on everytime the power blinks on and off in a storm :0) Best of all have a look in your manual and if you don't have it go to the manufacturer's site and download a new one or look for support there. Good Luck to you.
Posted on Jul 31, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Posted on Nov 26, 2008
jyackle5
  • 8197 Answers
SOURCE: error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Posted on Dec 18, 2008
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Posted on May 13, 2009
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
Repairclinic com
follow this steps and fix it. God bless you
Error Code
  • Clear the error code and stop the beeping by pressing the "Stop" and "Start" buttons at the same time. Unplug your washer so you can examine the problem.
Function
  • The error code displays because something is wrong with the motor sensor. This can be for a number of reasons. After you clear the code, try washing clothes again and seeing if the error appears. If it does, then you need to take further steps.
Read more: http://www.ehow.com/facts_7565280_kenmore-elite-error-code-f51.html#ixzz2aTwM1Z2u
Jul 29, 2013 | Kenmore 24032\24036 Top Load Washer
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
What does code F mean
F is part of a system fault code. There should be additional characters (numbers) in addition to the F.
Here's what I get from a Cabrio Owner's Manual if there are numbers after the F:
F## code (F-type error code) appears in display
System error code. Press START/PAUSE once to clear the code. Then press START/PAUSE again to restart washer. If code appears again, call for service.
I called Whirlpool at 1-800-442-1111, and according to customer support the manufacturer intentionally no longer provides descriptions for F codes (though there are still a few owners manuals that will describe something like F21 = Long Drain). Check to see if your owner's manual provides any F code help in the troubleshooting section.
Generally, what I was told is that F codes indicate customers need help from a technician. Not always completely true, and really not very helpful--especially if you want to attempt to avoid scheduling service.
Since there are numerous F## codes, please provide the specific code number if you desire further assistance.
Here are letter codes Whirlpool provided in the owners manual (copying from a PDF works poorly):
oL (overloaded)
appears in display
Load too large. If an overload is detected, the washer will drain any water and
detergent in the washer. Remove several items and add HE
detergent. Close lid and press START/PAUSE.
uL (unbalanced load)
appears in display
Load not balanced. The washer is
running a load-balance correction
routine.
Allow the machine to continue. If the dial is flashing and the
machine has stopped, redistribute the load, close the lid, and
press START/PAUSE.
LF (too long to fill)
appears in display
Washer taking too long to fill.
Drain extends more than
4.5" (114 mm) into standpipe.
Check plumbing for correct drain hose installation. Use drain
hose form and attach securely to drainpipe or tub. Do not tape
over drain opening. See "Installation Instructions".
Ld (too long to drain
water ) appears in
display
Washer taking too long to drain
water. Drain extends more than
over drain opening.
Lower drain hose if the end is higher than 96" (2.4 m) above
the floor. Remove any clogs from drain hose. See "Installation
Instructions".
etc...etc...
Jan 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Code 40
According to the Whirlpool installation and maintenance manual:
F _ _ “F##” code
Press PAUSE/CANCEL once to clear code.
Press START. If code appears again, call for
service.
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I keep getting error 20. How do I fix it.
error 20 in a general error try to Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash.
Sep 19, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My washing machine keeps giving me a error 20 code and dosent finish the cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes2.gif 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash2.gif. let me know what code come up... hope it helps
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
104 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
