Question about Briggs & Stratton Garden
Take sparkplug out starter turns motor easy hold finger over hole or put plug back in starter cant hardly turn motor tried new starter not it .valves are opening closing good acts like to much compresion but thats crazy.
5 Suggested Answers
  • 153 Answers
SOURCE: Ride on will not start. B&S motor.
Logic would dictate that the starter motor is burning out, drawing far too much current, and that the current overheated the solenoid and toasted it. Now the starter is almost a short circuit and while it spins it has no power. A spendy part to be sure. Perhaps you can find a used one from your friendly neighborhood repair guy.
A compression release is found on old diesel's, but not on gas engines.
Starters can fail from cranking on them for extended periods. They are designed to handle short periods of use, maybe 20 seconds on followed by several minutes (like 15) off. If you have had starting problems and kept cranking to get it going that would explain the fried starter.
Posted on May 14, 2009
SOURCE: engine wont turn over. too much compression.
jtd ride on mower wont start will turn over a little but if i take the sparkplug out it will turn over no problem any ideas please
Posted on Aug 30, 2009
  • 640 Answers
SOURCE: Can't get the sparkplugs to
The starting solinoid would not pull in if the safety switches were failed open. So starter would not turn. Did you replace the spark plug or test on another machine to verify spark? If so, when you replaced the coil were you careful to get the proper spacing from the flywheel. I have heard that you can use a business card to act as a feeler guage to set the coil distance from the flywheel. Too large of a distance will ensure that there is no spark.
If really helpful, please rate.
Posted on Jul 13, 2011
  • 6468 Answers
SOURCE: 18.5 briggs and straton engine , to much compression
check the push rods
Posted on Apr 23, 2012
My chrysler 300 touring 2006 won't crank. My wife went to the store and when she came out she put the key in the ignition and the car started for about 2-3 seconds and shut off. The never got a chance to...
Sounds like the motor is frozen. Remove all plugs and see if the starter can turn over the engine . If not that baby is seized if you are sure that the battery is good. Granted, I can understand your chagrin since to the best of your knowledge that engine did not over heat. Get another diagnosis and cross your fingers.
Sep 20, 2017 | Chrysler Cars & Trucks
Orion 125cc pit bike . just put new piston/rings in but turned motor & lost positioning , how do i get timing set up right
Hi, try taking sparkplug out and get a screwdriver and put it in the sparkplug hole then gently move the stater round with a spanner untill the screwdriver moves up when it is as high as it can go tdc then take the screwdriver out, then put the sparkplug back in the ht lead and put the electrode part of the sparkplug on the side of the head then undo the stater and turn the ignition on,then turn untill sparkplug sparks,tighten stater,put plug back in it should start,then you will need to put a timing light on for fine ajustment.
good luck I hope this was helfull,PH.
Oct 23, 2013 | Apollo Motorcycles
Toro zero turn mower does not want to start
i think that engine has a compression release arm on the camshaft f its not releasing it will be hard to crank over
Sep 27, 2012 | Toro Power Lawn Mower
Hi there, Just wondering if you would be able to help me. I was using my 4-stroke ride on lawn mower today through some really long grass. It turned off, and wouldn't start again. The engine is...
I would first check for spark by removing the sparkplug, put the wire back on it and ground the nut part on metal part of the engine and have someone turn the key. You should have spark between the gap of the sparkplug. If you are getting good spark take a straw and put it in a cup of gasoline then hold your finger over the top hole and put the end of the straw in the spark plug hole and release your finger from the top of the straw. Do that a few times, put the plug back in and connect the wire. Turn the engine over and if it tries to start you have a fuel problem. If it does not do anything you have to check the engine for compression whith a compression gauge.
Mar 15, 2011 | Garden
My 06 gsxr 750 will not start. New battery, getting fuel, replaced old fuel and bike will not turn over. What can I do to check if is getting spark?
if the bike will not turn over you mean it doesnt crank? because if it doesnt crank over then its a starter issue and could be a simple as a blow fuse, but then why did the fuse blow? ( starter going bad)..... or it could be the starter solenoid itself, and this is where i believe you might find the fuse. response feedback appreciated.
Apr 06, 2010 | 2008 Suzuki GSX-R 600
Yamaha yz 426 2002 set timing with crankshaft with index marks done this and camshafts oppisite facing , cylinder head lined with cam wheels how do i tell which is the compression stroke as might be 180...
take the sparkplug out and crank it over slowly when air pushes out is usually a compression stroke stop when the piston reach's the top..spin it over 2-3 times make sure you feel air rushing out the sparkplug hole put your finger in the hole it should push your finger out .
Nov 19, 2009 | 2002 Yamaha YZ 426 F
My mower (HRR) was hard to start and then would
It sounds like you are in need of a valve job on it. You can check this by removing the spark plug and holding a finger or thumb tightly over the hole while someone pulls the starter cord. If it doesn't literally "pop" your finger off the hole, you have a leaking valve and need to do a valve job or at the very least a valve adjustment
Oct 26, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Oil leaking into sparkplug holes on rubber boots
Buy a new valve cover gasket set (and a small tube of silicon high temp sealer). It comes with new rubber seals for each sparkplug hole, and the cover perimeter.Use a little silicon glue on the gaskets to hold them in place. Take your time,do the work with a cold engine in a shaded area. Clean all the oil off the wires and make sure all the old gasket rubber is cleaned off.And check to make sure before you put the cover back on that no old gasket pieces are in the engine.
Sep 20, 2009 | 1992 Honda Accord
Chranks hard,won't start
you need to adjust the valves with the cylinder 1/4 inch below top dead center to get the decompression lobe to function right during cranking.
Aug 07, 2009 | Garden
1996 ford ranger 2.3L 8 plugs single overheadcam
belt was broken set crank on tdc on compression stroke set timing mark on com set timing mark on oil pump gear? try to start it cranks but wont run check for spark and its gettin but still seems to be out of time starter doesnt crank smoothly replaced starter cranks better but still doesnt run
tried turning crank 1 turn and reinstall belt with same results have any ideas
Dec 02, 2007 | Timex (T307S) Clock Radio
Garden Logo
94 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
