Question about Bose Lifestyle 48 System
No signal from the media center in the PERSONAL music center II
No signal from the media center in the PERSONAL music centerII
2 Suggested Answers
SOURCE: No display or power to
check the power supply section burned components
Posted on Aug 01, 2011
Windows media player won't play any audio selections , says can't find files
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
Tip
How to make a Media center Shortcut.
Windows 7 Media center have multiple switches for customization.
Here is a list bellow.
/nostartupanimation stops the startup sound and Windows Media Center logo "pebble" going off into the distance /noshutdownui removes the "shutdown" item from the tasks menu /mediamode starts in media only mode (no close/minimize/maximize options in top right corner) /widescreen start in widescreen mode, even on 4:3 display (windowed only) /nochrome display windowed mode Media Center but without the window chrome /playallmusic plays all your music instantly /playfavslideshow plays your favorite slideshows only /playfavslideshowwithmusic plays your favorite slideshow with music /playslideshow plays all slideshows /playslideshowwithmusic plays all slideshows with music /screensaver starts the Media Center screensaver /configuress starts Media Center at the "configure screensaver" screen Examples: %windir%\ehome\ehshell.exe "/mcesuperbar://tv?live=true" – That will start Media Center in LiveTV mode
Yo can create custom shortcut by doing the following : Start > All Programs > Windows Media Center, and right click on it. Select properties. Under "target" you will see "%windir%\ehome\ehshell.exe".
Simply add the switches you wish Media Center to start with and hit OK.
For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
on Feb 10, 2010 | Computers & Internet
Hello I have a bose surround sound system in my house, both inside and out. It appears that only the inside portion of the surround system works and the remote for the outside portion the RC48S2-27 model...
I think we're discussing the Personal Music Center II.
I had to back into the product from the remote model number. Can we assume you also have one of the compatible LS systems (18 or 28 Series II or the 38 or 48) ?
You can go to Bose.com and search for it or register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Bose-Personal-Music-Center-II-Universal-Remotes-manual/id/526dj583/t/2/
The first item in Troubleshooting (page 28) might explain what's happening.
Jun 18, 2011 | Bose PERSONAL music center II System
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
How do i turn on the media center buttons?
Simply add the switches you wish Media Center to start with and hit OK. For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
Hope this helps.
Feb 10, 2010 | Gateway M-6866 15.4" Widescreen Laptop...
My m240
Before you can create a playlist and transfer (or synchronize) them to your Sansa
player, you need to show Windows Media Player where your songs are located.
Adding Music Files to Library…
To add music files to WMP 11’s library, follow these steps:
1. Click the arrow below the Library tab.
Loading Content 13
2. Make sure Music is selected then click Add to Library.
3. In Add to Library dialog box, click one of the following options then click OK.
- My personal folders:
Use this option to monitor the digital media files stored in your personal
Music folder as well as any files stored in the public Music folders that
everyone who uses your computer has access to.
- My folders and those of others that I can access:
Music folder, the files stored in the public Music folders, as well as the files
stored in the personal Music that belong to other users on your computer.
Oct 25, 2008 | SanDisk Sansa m240 MP3 Player
Bose 321 System Stuck on Hotel Mode!
Hey, try this out
-Press Enter and On/Off on the media center , on standby mode
-now hold the enter button pressed and start pressing the On/Off button. You should see a setting display on the player. The setting on display should change from video....till...Hotel Control -ON
- on that position, press the Volume 'minus' button on the media center. It should change to Hotel Control - Off.
Thanks
Brigade
Sep 25, 2008 | Bose 3·2·1 II System
Sync problems ...
The instructions with pictures are on pp. 13-19 of the user's manual:
Loading Music
You can transfer music from your computer to the Sansa player using the dragand-
drop method or using music managing software like Windows Media Player.
Drag and Drop
Follow these steps to drag-and-drop music to your Sansa e200 player:
1. Connect your Sansa e200 player to your computer.
2. Select Open device to view files using Windows Explorer on
initial connection.
3. Double-click on Sansa device.
4. Double-click on the MUSIC folder.
5. Drag and drop music files from your computer to My
Computer\Sansa e200\...\MUSIC.
Before you can create playlist and transfer (or synchronize) them to your
Sansa player, you need to show Windows Media Player where your songs are
located.
1. To add music files to WMP 11’s library, please follow these steps:
2. Click the arrow below the Library tab.
Loading Content 14
3. Make sure Music is selected then click Add to Library…
4. In the Add to Library dialog box, click one of the following options
then click OK.
personal Music, Pictures, and Videos folders, as well as any files
stored in the public Music, Pictures, and Video folders that everyone
personal Music, Pictures, and Videos folders, the files stored in the
public Music, Pictures, and Video folders, as well as the files stored
Loading Content 15
in the personal Music, Pictures, and Videos folders that belong to
Mar 12, 2008 | SanDisk Sansa e250 MP3 Player
Bose Lifestyle 48 System Logo
367 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
