Question about Xerox C2424 Copier
Wrong ink Someone has put black into the cyan slot. How can i get it out? There are 3 cyans on top of it. Engineer will charge £220!
    Novelist:
  • 208 Answers
The easiest way to remove one is to take a screw and run it into the ink stick then slide it backwards until you can pull it up out of the install opening.
Repeat that until you have removed all the sticks.
Posted on Dec 03, 2007
  • 163 Answers
Pleze make many copies at dark when finish the ink replace it with new
Posted on Sep 13, 2007
SOURCE:
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade, www.hp.com
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Nov 01, 2011 | HP LaserJet 4700 Printer
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I have a HP color laserjet 5500dn that wont print cyan. Has anyone had this problem
Get into MENUS, go to DIAGNOSTICS, PQ TROUBLESHOOTING. Check the cyan.
Clean the contacts on the cyan cartridge, replace the cyan cartridge, Replace the High Voltage Board. The laser scanner for that color may have to be replaced. The DC Controller could be bad.
Also, under DIAGNOSTICS there is a "Disable Cartridge Test".
That test will allow you to remove all the cartridges and swap them around(in other words, put the cyan in the black slot and the yellow in the magenta slot) and print. So why don't you run that test and swap the cyan and the black. Print and see if the problem follows the cyan cartridge. If it does, replace it. If the problem stays with the original slot for the cyan, then the stuff mentioned in the first paragraph comes into play and you may need a tech to look at it and replace parts.
Good luck
Mar 31, 2011 | HP LaserJet 5500 Printer
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
ERROR6502
Error 6502 is a ink tank position error, one of the contacts for the ink tank in the carriage could be bad, or simply a wrong cartridge installed. You can't use photo magenta in a magenta slot, or photo cyan in a cyan slot.
Jul 15, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Ink in blue slot is not dissolving
If your printer still can print but with no cyan color then you most likely have a bad printhed. If your cyan ink is not melting it's because it is not using any ink . Get into the "print quality" menu and print the test page. If you get black, yellow, and magenta but little or no cyan then your printhead is bad. Whith these machines cyan is the first color to have poblems starting with weak or missing jets.
You can try to run the "eliminate light stripes" to see if it will help.
Run it about 3 to 5 times. If still not working right, turn the printer off for at least 4 hours and then test again.
Hope this helps,
Dan
Oct 28, 2008 | Xerox Phaser 8500/DN Printer
Ink cartridge cyan is not working
Beside of the color ink there are photocouplers, check them
May 14, 2008 | Brother MFC-5840CN All-In-One InkJet...
Xerox C2424 Copier Logo
60 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
