Question about Kodak EASYSHARE 5100 All-In-One Printer
Even with new printhead, etc, the thing still says paper jam and.
Won't print. the prinyhead won't move to the center. really, after three calls to support and a promise of a new printer, all i get is a printhead and that solves nothing. the directions were followed to the letter! there is no paper jammed; it is empty! where is the nearest place I can take this piece of junk to get it serviced under warranty?
  • 2 more comments
  • rowdylynn Apr 13, 2009
    I'm still waiting. Why are there no directions for my machine, which in fact is an ESP7? It's a paper jam problem.
  • rowdylynn Apr 14, 2009
    well, it worked fine for a while but just stopped 10 days ago, saying paper jam but there is no paper. There have been no changes, additions, deletions, etc, and all i'm trying to print are e-mails and word processing docs. The lights are lit and the turning it off and back on doesnt make any difference, the red light above the ok switch is blinking. the printhead stays either far right or far left. Hitting the okay button only brings up the same paper jam message. Paper path has been checked; it is clear.
    I'm becoming very frustrated and that' not good.
    It is not an Epson, it's a Kodak! And it still isn't working (saya "paper jam)
  • rowdylynn Apr 17, 2009
    well, guys, it's been about 72 hours since hearing from you. Gave up, huh? Don"t know why I messed w/you to begin with. Adios!!!!
    Brigadier General:
  • 5,158 Answers
Do you have the user manual for the printer i need you to confirm one thing
Posted on Apr 18, 2009
  • 6,487 Answers
This is already a sensor problem, that's why its always saying paper jam even there's no paper jam on the system, you really better have this unit replace from Kodak....
Posted on Apr 14, 2009
  • 527 Answers
Sir,
Check this link u have lot of information relating to paper jam error / printer head problem. Just to search and go through the link and read out
Thanks
Good Luck
Appreciate to rate as "FIXYA"
  • 530 Answers
Hi. friend. standby for a while,i'll sent you how.
Posted on Apr 13, 2009
  • 3 more comments
  • Joseph Baculan
    Joseph Baculan Apr 13, 2009
    Understanding Potential Problems
    Printers are mechanical devices with lots of moving parts. And any time you have moving parts, you have something that can break or wear out over time.
    So when you click the old print button and nothing happens, what are the likely causes?
    First, you might have the wrong printer driver installed in Windows. You might have either simply selected the wrong driver for your printer, or Windows might have mistaken your printer for another model, or the driver selected might be out of date. While we're in this area, it's also possible that various aspects of your printer setup might be incorrect, which can cause some highly unusual problems. You should also check your font setup because fonts themselves can cause perplexing problems if they're not installed correctly.
    In addition, any new input or output device you've installed since you installed your main printer could have changed your printer's settings. (It's kind of like the last device installed gets dibs on key system settings.) If you've recently added a scanner or a digital camera or fax software or anything like that and then experienced printer problems, try uninstalling your printer (and all printer drivers) and then reinstalling your printer so that your printer is now the last device installed—and thus controls key system settings.
    It's also possible that if you're printing large or graphically complex documents, you might not have enough disk space or memory to print. Make sure that you have plenty of both, because Windows needs all the space it can get to complete the printing operation.
    Finally, you could have real printer hardware problems. These problems range from the mundane (you're out of paper, you forgot to turn on the printer, a cable came loose) to the fairly serious (your printer is broken!). Check all your cables and connections and make sure that your printer is actually turned on.
    The bottom line is there are a lot of things you need to check if you have printer problems, both hardware- and software-related. So if you have printing problems, hunker down and plow through the problems/solutions section, coming up next.
    tip
    One of the best ways to track down a printing-related problem is to use the Windows Print Troubleshooter, found in the Help utility.
  • Joseph Baculan
    Dealing with Printer Problems
    The types of problems you might encounter with your printer fall into four basic categories: The printer has no power, the printer doesn't print, the printout is garbled, or pages of the printout are missing. Read on to find out more about each problem and ways to solve it.
    Problem: Your Printer Has No Power
    This is the perennial problem with computer hardware. By now you know the drill:
    Make sure that the power cord is plugged into both the power outlet and the back of the printer. Make sure that the power outlet has power; check all fuses and circuit breakers, as well as surge suppressors. Make sure that the printer is online. (This is normally accomplished by a front-panel button of some sort.) And check the internal fuse in the printer itself.
    If all the right parts in your system have power and your printer is online, your problem is more serious. The biggest potential source for this type of problem is the power supply in the printer. If this is causing your particular problem, it's time to call the repair center and ready your checkbook.
  • Joseph Baculan
    Problem: Your Printer Has Power but Doesn't Print
    The first item to check is whether your printer is connected correctly to your computer. Check the connecting cable to make sure that the connections are tight. You also should unplug each end of the cable to ensure that none of the connecting wires are bent, making a bad connection. You might also want to change the printer cable. Cables can get old, and the wires inside can break; try a new cable and see whether this change fixes the problem.
    caution
    Anytime you change any connection between your system unit and any external device (such as your printer), you probably need to turn your computer off and then back on again for the connection change to register with your system. So if you're plugging in cables, reboot your system when you're done.
    Next, you should make sure that the printer is connected to the correct port on the back of your computer. Checking the port connection is not always as simple as it seems. Some computers come with more than one printer port, and your printer might be hooked up to the wrong one. If you have multiple printer ports, try plugging your printer into the other ports.
    Next, check the paper feed of your printer. If you're out of paper, your printer can't print. You also should check the paper path inside the printer to make sure that no stray pieces of paper are lodged inside. Make certain, too, that your printer is online, or set in the on position.
    You should also check to see if your printer is paused. Check your front panel buttons to make sure that your printer is online. You should also double-click the Printer icon in the Windows system tray to open the Print Manger and make sure the job isn't paused from within Windows.
    Another potential cause of this problem is having the "manual feed" option selected in Windows or on your printer. If this option is selected and there is no paper in the manual feed tray, your printer just sits there waiting for someone (like, oh, you!) to insert some paper. The solution to this is to either add some paper to the manual feed tray or switch off the manual feed option.
    It's also possible that you have the wrong driver installed or selected within Windows. Right-click on this printer's icon in the Printers window and select Properties. Check the Details tab to make sure you're printing to the correct port using the correct driver. If you need to change drivers, pick one from the pull-down list, or click the New Driver button to add a new printer driver.
    note
    The tabs in the Printer Properties dialog box are specific to the brand and model of printer you have installed. If your Print Properties dialog box doesn't have a Details tab, look for a
  • Joseph Baculan
    It's possible that the correct driver is installed, but something has gone screwy with how Windows reads the driver information. Go to the Printers Window and delete the current printer, and then use the Add Printer Wizard to reinstall the printer driver. You might also want to check with your printer's manufacturer to see if there is an updated version of your driver available.
    In addition, it's possible that a recently installed device has somehow mucked with your printer configuration in Windows. Try deleting your printer driver and then reinstalling it, as described in the previous paragraph. Because the last device installed on your system can overwrite previous configuration information, go ahead and make your printer the last installed device.
    If none of these suggestions solves your problem, you're looking at a major computer or printer problem. Try hooking up another printer to your computer; if the new printer works, it's time to take your old printer into the shop. If the new printer doesn't work, you probably have a defective port in your computer.
    Problem: Your Printer Prints, but Output Is Smudged or Garbled
    If your printout is not as you expected, there might be several causes. The most likely cause, believe it or not, is our old friend the poorly connected cable. If all the instructions don't make it from the computer to the printer, your printout will be incomplete, if not totally out of whack. Check all cable connections to ensure a good throughput of data. If that doesn't fix the problem, just change the printer cable. An old or damaged cable could be causing your problems.
    tip
    Printing the printer's self-test page is also a good way to determine whether the problem is in the printer or in the computer—or somewhere in-between.
    Another cause of print garbage might be the printer itself. If you have a low or old toner cartridge in a laser printer or a near-empty ink cartridge in an inkjet printer, your printout will be lighter than normal, perhaps even unreadable. If necessary, change the cartridge and run the print job again.
    If you're using a laser printer, you might get black streaks on your output. This problem is most often caused by an old toner cartridge, or by a dirty roller or printer cleaning bar. If you replace the toner cartridge and clean the suspect parts (using a cotton swab) and you still experience black streaks, your printer might need service.
    If you're using an inkjet printer, it's possible that your print jets are clogged. You'll need to unclog the print jet by inserting a small pin into the jet.
    It's also possible that a paper misfeed in your printer caused the printout to become smudged or out of line; if this is the case, straighten the paper feed and start the print job again.
    An incorrect printer setup in Windows can also cause unusual printouts. Make sure that Windows is configured for the exact type of printer you're using. Also make sure that you have the correct landscape (horizontal) or portrait (vertical) printing option selected.
    If none of this works, you probably have a problem somewhere in your printer. Although a bad printer port on your PC could be the culprit, more than likely some internal problem with your printer is causing the poor printout. (You can confirm this by printing a self-test page; if it looks bad, the problem is in your printer.) Consult your friendly repair center.
  • Joseph Baculan
    Problem: Your Printed Page Looks Half-Finished
    If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
    • Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
    • Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
    • Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time!
    Problem: Your Printer Prints, but the Fonts Aren't Correct
    If you create a document on a PC with one set of fonts installed, and try to print it on another PC with different fonts installed, you could be in for a real surprise! Windows will try to "match" missing fonts, but quite often the match leaves a lot to be desired—resulting in different line lengths and page breaks than what you had originally. Your options are to install the missing fonts on the PC you're printing from, or change the fonts in the document in question. (A word to the wise: stick to common fonts such as Arial and Times New Roman if you think you'll be sharing a document on multiple PCs.)
    Problem: Your Color Printer Doesn't Print All Available Colors
    This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge.
    Problem: Paper Jams in Your Printer
    It's possible that your printer's internal paper feed mechanisms are getting dirty. You can try taking the printer apart yourself to clean out any pieces of scrap paper or other debris, or you might want to take it into the shop to let a pro deal with it.
    You might also be getting some paper sticking to other sheets of paper in your paper tray. (This happens more often with cheaper paper—spend a little more and get the good stuff!) Try thumbing through the stack of paper before inserting it into the tray; this should loosen up the paper and make it feed easier into your printer.
    Finally, you might need to change the grade of paper you use with your laser or inkjet printer. Lightweight papers tend to jam up the works, so switch to something heavier if you experience a lot of problems.
    THE ABSOLUTE MINIMUM
    • Most printer problems are caused by a bad cable connection, a misconfiguration in Windows, or a bad or outdated print driver.
    • All printers need periodic maintenance; make sure you regularly change toner or ink cartridges, clean the paper path and feed, and—if you have an inkjet printer—use the cleaning option to clean the ink jets and cartridge.
    • If you're having trouble printing graphically intense documents on a laser printer, you might need to add memory to the printer or simplify the documents.
    • Lightweight paper can cause unexpected paper jams; use a better grade of paper to keep things running smoothly.
Printhead carriage jam
It all depends on who made the product. There are often times simple solutions but they need to be found by searching on the web and talking to service people about the unit. Some print head motors were known to fail or develop bearing noise over time in the HP line. Many of these things are really not prone to be fixed as the repair cost is sometimes the same as a new unit.
I would contact the warranty center- even if out of warranty and see if you could talk to a technician to start.
Aug 29, 2012 | Kodak ESP 5250 All-in-One Printer
Lexmark Prevail Pro705 printer jams each attempt to print. Reasonably new, Lexmark just replaced printhead and ink cartridges under warranty and printer gave better print results than when brand new. Joy...
Make sure your printer is updated. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update on your computer. The update will make your printer more reliable and more efficient.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 13, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
I have a ESP7 all in one printer. The error says Paper Jam, no error number. The problem is there is no paper jam...I believe the problem exsits with the printhead it is not moving to the center, there...
There may be three things that are causing your printer to report a paper jam error when there is no apparent paper jam.
1) The printer is picking up the paper feed as a jam
Remove all the paper from the printer. Turn the printer off at the mains for 30 seconds. Turn it on and try printing with just 1 piece of paper in
2) There may be a bit of paper stuck on one of the sensors inside the printer.
Open the top of the printer and look very carefully around the rollers at the edges and manually turn them to check if there is any small bits of paper
3) There may be dust on one of the sensors.
Open the printer and blow inside it or ideally use a can of compressed air to clean the printer.
Regards,
sjstore2
Dec 18, 2010 | Office Equipment & Supplies
Printer says there is a paper jam and there is no paper in there.
first thing you need to do is will do the overriding the error
1. open the pritner access door fo the printer
2. if the printhead or ink cartirdges already in center remove the ink cartridges and the printhead
3. If the printhead already removed close printer access door., Turn Off the pritner then after 10sex turn It own.
4. Now your pritner should detect no printhead installed not paper Jam., If you still recieved paper jam error without the pritnhead installed you need to have a printer replacement call kodak toll free number 1 800 421 6699 ext 05
5. Now if the message is pritnhead not installed., reseat the printhead and the ink cartordges then close the pritner access door., If your ecived same message paper jam., You need to replace the printhead you may also call kodak 1 800 421 6699, and have your free printhead replacement.
Most of the time overriding the error message solve the problem
Nov 17, 2009 | Kodak ESP 5 Printer
I keep getting a paper jam, I don't know how to fix this,
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printer if the printhead is not moving to the center or if it is stuck on the right side
Hope this will help
Thanks
Byron
Aug 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Mar 19, 2009 | Kodak ESP 5 Printer
PIXMA MP830 All In One machine will not operate error code 6A00
Do you have a led error code or error on the lcd display ?
Aug 07, 2008 | Office Equipment & Supplies
Paper Jam but not really???
If it's a brand new printer, try removing and reinstalling the printhead. An incorrectly installed printhead will give you a false paper jam error.
Jul 05, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
No black print
I work for kodak with these printer's.
I provide tech support for them.
For this problem all i would recommend is doing the deep clean on the printhead twice, Doing it more then twice is a waste of ink and if it doesnt fix it the second time it won't.
Also replacing the black ink cartridge.
Also calibrating the printer has worked for me a few times.
I would not recommend cleaning the printhead manually, thats more of a chance to break it then fix it.
I would just recommend calling into the kodak tech support and getting a replacement printhead to fix that clogged nozzel problem.
Jan 19, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Paper jam Brother MFC-215C
Norman,
does the printhead run smoothly to the left side of the printer when it is powered on?
If the printhead cant run that freely, it will give you the paperjam message. You have to dismantle the printer again, connect the scanner and cables again when top cover is removed. Press the scanner open contact (opposite to the menu button) and watch the printhead run to the left side. It might be that either the printhead stucks somewhere on its way (press the cover of the printhead. It might be the reason) or the guide rail hinders the printhead to move.
Oct 13, 2007 | Brother MFC 210C All-In-One InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
77 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
